Doh
Doh
Dan Deyo
92 Acura Integra
ITA #94
Don't think I understand the question. You have to use OEM internals of everything in an IT engine, except .040" overbored (max) pistons, which must otherwise be "OEM-style" in every other dimension and design.
Kevin
2010 ITB ARRC Champion
2008 & 2009 ITA ARRC Champion
'90 FP Acura Integra RS
'92 ITA Acura Integra RS
'92 ITB Honda Civic DX
'92 Honda Civic Si
"Experts from the street scene" will say swap, turbo, nitrous, or any combination of the three. I've built B18A/B IT engines, Prod engines, and "street" engines - completely apples to oranges on all three. Today I'm actually installing a fresh "turbo build" B18B into a Civic that's going to be pushing about 14psi of turbo'y goodness - wooosh!
Kevin
but it does say we can run Factory replacement pistons or their equivalent
with the exception of diameter shall be used. Cast or forged
equivalent pistons shall provide the same dome/dish/valve relief
configuration, ring groove width and spacing
Which is exactly what Kevin said above...
