Results 1 to 13 of 13
Thread: b18a1 build up
    Jun 2011
    new york
    11
    Default b18a1 build up
    just wondering if anybody had an idea on a rotating assembly for a b18a1 that is scca ita legal.
    Dec 2007
    West Hurley, NY
    388
    How about the Eagle rotating assy?
    Dan Deyo
    92 Acura Integra
    ITA #94
    Jun 2011
    new york
    11
    hi dad lol
    Dec 2007
    West Hurley, NY
    388
    Doh
    Dan Deyo
    92 Acura Integra
    ITA #94
    Nov 2001
    Columbus, OH
    1,522
    Don't think I understand the question. You have to use OEM internals of everything in an IT engine, except .040" overbored (max) pistons, which must otherwise be "OEM-style" in every other dimension and design.
    Kevin
    2010 FP Runoffs & Super Sweep Champion
    2010 ITB ARRC Champion
    2008 & 2009 ITA ARRC Champion
    '90 FP Acura Integra RS
    '92 ITA Acura Integra RS
    '92 ITB Honda Civic DX
    Dec 2007
    West Hurley, NY
    388
    Quote Originally Posted by R2 Racing View Post
    Thought so!!!!! Just sorting out a new car build. Trying to make sure we balance
    what is legal against what all the "experts" from the street scene say we should be
    doing with an Integra.
    Dan Deyo
    92 Acura Integra
    ITA #94
    Jul 2006
    Sunnyside, NY
    1,197
    Quote Originally Posted by wepsbee View Post
    yay, don't listen to sales folks unless it's Mark from King.
    Demetrius Mossaidis aka 'Mickey' #12 ITA NESCCA
    '92 Honda Civic Si
    STFU and "Then write a letter. www.crbscca.com"
    2013 ITA NARRC Champion and I have not raced since.
    Nov 2001
    Columbus, OH
    1,522
    "Experts from the street scene" will say swap, turbo, nitrous, or any combination of the three. I've built B18A/B IT engines, Prod engines, and "street" engines - completely apples to oranges on all three. Today I'm actually installing a fresh "turbo build" B18B into a Civic that's going to be pushing about 14psi of turbo'y goodness - wooosh!
    Kevin
    Jun 2011
    new york
    11
    but it does say we can run Factory replacement pistons or their equivalent
    with the exception of diameter shall be used. Cast or forged
    equivalent pistons shall provide the same dome/dish/valve relief
    configuration, ring groove width and spacing
    Nov 2005
    Jacksonville, FL
    734
    Which is exactly what Kevin said above...
    Jun 2011
    new york
    11
    so even if the eagle crank is the same weight stroke as factory its prohibited ? just looking for a cheaper replacement than a oem acura one and they can come balanced
    Oct 2005
    168
    You don't just want the crank balanced, you want to balance the flywheel, pp and front pulley with the crankshaft. Plus every Honda crank that I have put on a balancer is already balanced.
    Blake Meredith
    Jun 2011
    new york
    11
    thanks for the input
