Results 1 to 3 of 3
Thread: idle surge when brakes applied
    Jul 2001
    Chicago, IL
    253
    Default idle surge when brakes applied
    Hi, is it normal for the engine to surge a couple hundred rpm when the brakes applied and released at idle? Its a A2 (1987) scirocco. I'm wondering if the vacuum booster is bad - have changed vacuum lines. Thx
    Jan 2010
    Houston-ish
    932
    If it's a short-term surge, that sounds iffy but not too bad. If the idle moves and stays while you're on the brakes, then I'd suspect a bad booster.
    another way to check is to stick a vacuum pump & gauge on the booster. Try to pull a vacuum on it and see if it bleeds down with time.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Sep 2008
    FL.
    1,384
    Yes, it will move a little RPM.
    Check the O ring on tha back of the MC. It needs one to seal, not many MC come with, and it is easy to leave out.
    MM
