Results 1 to 18 of 18
Thread: Goodyear Eagle RS Dot
    Default Goodyear Eagle RS Dot
    I need a new set of tires if I'm going to run my ITB Volvo any more this season. I've been runnig Hoosier R6 which seem to use up the rubber before the grip goes away and have been working out pretty well. However the Goodyear dealer was telling me how great their new tires are. So... Is any body using the new Goodyear's?
    Has anyone done testing against the R6's?
    Lastly, Ive been using the 225-45-15 R6 on 6 inch ITB rims. They sure are a struggle to mount and the inside 1/2 inch of tread shows almost no wear from tread distortion arising from these narrow rims. I'm thinking of trying the 205-50-15 for a better fit on the 6 inch rims. Has anyone tried the goodyears on 6 inch rims and care to comment on size selection.
    Charlie
    Nov 2001
    Bunker Hill,WV.
    614
    Charlie
    Pam Richardson knows some things about this tire. You may want to chat with her about it.
    cheers
    dave parker
    "Ignore All Confrontations With Common Sense."
    Oct 2004
    Northeast
    7,031
    Charlie,
    I use them and love them. You will find the 205/50/15 GY is almost as wide as the 225 Hooiser. My experience is that they take an extra half lap to come to temp but are more stable over a race and less resistant to flatspotting.
    I think they are at LEAST as good at the R6.
    Not 6" info because I use the 7s but some info at least.
    Andy Bettencourt
    New England Region 188967
    Charlie,
    The old Goodyear GSCS took a bit longer to come in too but really worked well on my heavy Volvo. How do they hold up? Durability is a big factor on this years budget and I remember the GSCS would heat cycle out much sooner then the current R6.
    Thanks Dave, I'll check with Pam.
    Dec 2005
    Port St. Lucie, FL
    354
    Charlie,
    How many competitive heat cycles have you seen out of them? We just tried a set, and they were great through the first 8-9 cycles, but seemed to have tailed off precipitously at this point.
    Chris Carey
    Central Florida Region
    ITS/Vintage Datsun 240Z
    Favorite tool to remove undercoating---- A curb!
    "Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
    Oct 2004
    Northeast
    7,031
    I only use them for 6-8.
    Andy Bettencourt
    Thanks, Andy
    Sep 2002
    Fredericksburg, VA
    1,191
    Resurrecting this one since it seems to be the most recent: I'm going to be trying a set of the Goodyears this weekend, partly because I've heard good things from a few different people, partly because nobody is bringing Hoosiers to the track . My question is, I've heard that the GYs like a lower hot pressure than the Hoosiers & Hankooks - are you guys who run them finding this to be true? If so, what kinds of hot pressures are you looking for?
    Thanks.
    Earl R.
    240SX
    ITA/ST5
    Apr 2007
    New Bern, NC
    340
    earl,
    i am using them on my mustang. my experience has been that they dont build up pressure as fast as the toyo or the bfg's that i have been using. i have only one weekend on them, but it was in 100 degree heat at VIR.
    for me the main difference has been that the goodyear likes a lot less negative camber. nearly a full degree less.
    Rob Bodle
    Rob Bodle Images, LLC
    RBI Competition
    2007 ARRC Three hour "not a real" Enduro ITO Co-Champion.
    2009 ARRC ITO Champion.
    2009 ARRC Enduro Pole Winner
    2010 ARRC ITO Champion(car owner for Cliff Brown)
    2011 ARRC ITO Champion
    Feb 2007
    Philly, PA
    126
    I also just picked up a set for RS's. I would be interested to hear the comments on pressures as well!
    Wes
    29 ITS
    Oct 2004
    Northeast
    7,031
    I like them at 35 hot.
    Andy Bettencourt
    I thought the compound was a bit harder then the R6's. They wore like iron and had absolutely no fall off of grip at the end of the race. But, not sure they were as sticky. Pressures were close to 40# hot. This was at the MARRS Labor Day race in a RWD Volvo.
    I'll try lower pressure this weekend.
    Andy, have you tried the softer compound (autocross) on a road course?
    Oct 2004
    Northeast
    7,031
    Quote Originally Posted by Charlie Broring View Post
    Just A6's. I am sure that the GY is as grippy as the R6.
    Andy Bettencourt
    Sep 2005
    BEAVER,PA
    273
    so,they measure big compared to Hoosiers.......they must look like monsters next to hankooks. Just so I understand a 225 Hoosier is LARGER than a 225 Hankook and a Goodyear is LARGER than a Hoosier. What is the price comparision?
    Greg
  15. #15
    Sep 2002
    Fredericksburg, VA
    1,191
    Quote Originally Posted by gpeluso View Post
    Greg
    Hooosier - $228
    Goodyear - $225
    Hankook - $170-$200 (depending who you get them from)
    Earl R.
    240SX
    ITA/ST5
  16. #16
    They do measure big. I used 205/50 GY's instead of the 225/45 Hoosiers that I had been buying. The 205's are cheaper too.
  17. #17
    I raced on the Goodyear's again at this past weekends MARRS race and ran some of the fasted ITB times that I have ever run. I guess they are sticky after all. Fastest lap was on the 7th heat cycle, so they are proving to be durable too.
    Slightly lower pressure seemed to work, but I may have gone too low with my starting pressure on one occasion. It would be nice to hear more observations about hot tire pressures
  18. #18
    Oct 2005
    189
    The only caution I would put out there about the goodyear is that it soaks up alot of HP because it is such a grippy tire. When it first came back on the market 4 or 5 years ago, we were running the 13 hr at VIR. They had an open tire rule for SM so we thought great, will run it. We buy 3 sets. We get there and all three drivers were 3 seconds slower a lap. According to the data it was not corner speed. We had been there the 3 previous years. Something must be wrong with the car we think. We figure, what the heck, lets see how we do on the RA1's. We pick up those 3 seconds. All in straightaway speed. The data doesn't lie. The car had 0 toe. It cornered fantastic. Just didn't have the power in a straight line. So for an under developed car, I'd say do not use then. For a front row car, go for it.
    Chris
