Yes, and be sure to have proper tabs/tubes installed for 5th or 6th points. I expect 5 point belts to be gone soon with 6 being minimum so be prepared. Good luck with the build.
Steve Eckerich
ITS 18 Speedsource RX7
ITR RX8 (under construction)
David Plott
Atlanta Region #289721
#54 1973 Datsun 240Z
Mount Juliet, TN
In the rear for the lap belts we use 1/4 thick tabs to bolt the harness in or to attack anchor eyes for snap in style. If you run a bolt through a tube it should be sleeved to prevent a break point. Just sold the last 2 cars with this setup so I will see what I have pictures of.
Steve Eckerich
For gaps in the GCR I always look at the FIA specifications. Frankly I trust the FIA specs a bit more as they back up most of their findings with engineering and testing. There are a few diagrams of seatbelt mounts and the rollcage bushing you mentioned. Take a look at this:
http://argent.fia.com/web/fia-public...11)-080910.pdf
David Russell
IT Volvo 242
Just went through this with my new tub and cage. The shop welded anchor eye-bolts to the seat frame for the lap belts and 2 sub belts for a 6-pt system. Make sure you go over how you want the belts mounted with the shop. There seem to be some differences in how belt manufacturers want you to mount the them.
Good to see you're getting to the point of a new cage. Hope to see you back at the track soon.
ITA 240SX #17
Atlanta Region
Keep in mind that (even back in 1969) Nissan and most OEM designed their seat mounting in a side impact to move to move inwards as the trans mount broke, the trans drops down, and the tunnel collapses. This give as much crush zone as possible in a side impact. Later cars have structures called "pusher blocks" that physically move the seat inward in a side impact.
I would be reluctant to mount the seats directly to the cage for fear of too much impact force being transmitted directly into the seat.
FYI... in the 240Z's case, look at the scallops in the front set mount and how the rear seat mounts are two separate pads separated by just the pan. Also, look at the trans mount in 1972 and later 240Zs. I've seen 240Zs hit the in sides where the seat moved 10" inward delaying the load imparted to the driver.
