Results 1 to 4 of 4
Thread: Fuse failure
    Dec 2001
    raleigh, nc, usa
    5,252
    Default Fuse failure
    Anybody ever have a fuse fail in the "non-visible" part of the fuse? I did. Fuse looked visibly fine, but it was dead when I got a multi-meter on it.
    Ruint a track day trying to hunt this failure down......
    I guess always just a smart thing when you have a weird electrical failure to replace a few critical fuses one by one and see what you get (or carry a multimeter, which I will now do at Dr. Earp's command......).
    NC Region
    1980 ITS Triumph TR8
    Nov 2004
    Lilburn, GA
    597
    I always thought fuses were designed to fail in the visible portion. I.e. the metal there was what determined the amp rating of the fuse. I guess if the metal was the same all the way around then it could fail anywhere.
    I figured you'd carry a couple multi-meters since British electrics are so renowned. I keep one in the toolbox and I have a Nissan.
    ITA 240SX #17
    Atlanta Region
    Jan 2002
    Somewhere in Upstate New York
    1,033
    Yes...they can crack or fracture in the "non-visible" parts...not uncommon at all. Have several buildings full of the little dears, and the techs all know that they've got to "ohm-out" any fuse, even if it looks OK.
    Dec 2001
    raleigh, nc, usa
    5,252
    Thanks John. That makes me feel better about this. I had no idea a fuse could fail that way.
    Got two laps in on a test day before that happened. I am an idiot; should have just replaced the fuses (cheap).
    NC Region
