Yeah, but I was thinking about the resistance of a coil-some call them springs!
phil hunt
"thats a no-no. meter must be unmodified."
That's why I wanted to know the literal rule. If the rule allowed changing the resistance of the sensors, I would argue that the adjustable spring that varies the resistance of the flapper to airflow would fall in that legal/specific category.
Please don't confuse intent with grammar school English please.
phil hunt
post #10 in this thread already covered it, it's GCR 9.1.3.D.1.C
stock air metering device "shall not be modified." if you change the coil spring or the closed torque from the stock setting, you have modified it. if you vary, short, add, etc... resistors or other passive electronics INSIDE THE METER, you have modified it. the intent, apparently, is that you can do whatever you want to the circuit so long as its done through the wiring OUTSIDE of the meter, or in the ECU, and that it is to remain mechanically as stock.
I gather that you want to have the thing in the airflow, unplugged and using a MAP like most of the modern ECUs can, and set the spring to have less resistance to limit the resistance to intake air flow. 1 - you can do that, but you must leave the meter internals alone, and 2 - removing that restriction to flow wouldn't make much difference (if any) anyhow, that's not really holding the motor back.
expect ~106rwhp if you build the motor to the 9's, aftermarket ECU, modified distributor internals and all that, in a fully legal IT build. it just wont make the numbers to hit class power to weight. it's a well known issue, unfortunately. we have 2 and another on the way, so I feel your pain. build it, legally. ask questions like this whenever the mood strikes you, make sure everyone knows what you have done, and what kind of power you are making, on what dyno. the more evidence we have to support the weight change requests, the better (or so I'm led to believe).
