Okay, I just read through the IT specs, and most of the GCR, for the first time in about 4 years. I see that we can now completely replace computers, add MAF and/or MAP sensors, and some other key bits. Unfortunately, I didn't see any provision to swap out mechanical injectors for electronic injectors. Did I miss it?
Assuming I didn't miss it and there's just no provision for electronic injectors yet, can CIS-basic (K-Jetronic), CIS-Lambda (KL-Jetronic), CIS-E (KE-Jetronic), or CIS-Motronic (KE-Motronic) cars take much advantage of the new rules in current form? If so, what might be considered within reason and worthwhile? The very early CIS-basic had a mechanical computer, namely the CIS metering unit. All of the later versions had metering units with some electronics attached to electronic computers. For all versions including the early basic, the cold start injector was electronic, but typically not well placed for even fuel distribution.
