Results 1 to 6 of 6
Thread: Toyo RA1 Tire pressure?
    30lb is a good start
    38-40 hot should be good.
    Keep in mind that at the start of a school or in the damp the tires will not heat up as much so you may want to start at like 32 ft and 34 rr. As the driving gets more agressive, just manage to the hot temps after the car comes off track. Watch for one corner or side to get warmer and more pressure than the others due to the particular track or the car. Note that and keep in mind for when you rotate tires or go out for the first time in the morning.
    Tom Broring
    Wash DC Region
    ITA Nissan Sentra SER
    HP Triumph Spitfire
    HP VW Rabbit
    May 2002
    Glendale,Wi
    210
    Thanks all. A little different than my GTL car and slicks. My notes confirm what everybody said.
    Wheaton, IL
    1,893
    I ran them much lower - 23-24F, 18-19R. But they were a real handful until temps came up.
    Keep it simple in this case.
    Chris Schaafsma
    Golf 2 HProd
    Nov 2009
    12
    An 8 time MARRS champ I know believes that 38 lb. hot is golden on his Miata. Start with 31 on the tire generally on outside of the turns and 32 on the other side.
