Results 1 to 13 of 13
Thread: Initial alignment settings (warning: noob?)
    Oct 2009
    Spooner, WI
    87
    Default Initial alignment settings (warning: noob?)
    Hello,
    My school for Blackhawk Farms is a couple weeks away and was wondering what the alignment settings should be for a '84 Scirocco (equipped w/ camber plates, coilovers, Bilsteins, unknown springs with half used up Hoosier R6's).
    The PO indicated:
    Front toe out .06 at the wheel
    Max front camber
    front caster 2.5 deg. Verify tire temperatures
    Rear alignment should be set by shims. 0 toe, 1.8deg camber check tire temps
    Are these correct or any other suggestions?
    TIA,
    Feb 2007
    292
    Close, but the camber should be -2.5 to -4.0, and caster should be maxed out.....
    ______________
    Waterhaus Racing is Back!
    NRSCCA Competition Chair
    BOG Member
    Still working on a name...
    X-MVRG Member...
    ITB Rabbit/ITA Miata
    Wheaton, IL
    1,893
    My BHF setup:
    -3.5 LF camber -2.5~-3 RF camber.
    zero front toe
    starting pressures I need to go look up, but I think 33-35F, 31-33R on R6s
    Your rear stuff looks fine. I think I am at -2 camber there, but it has way less impact than the front end.
    Chris Schaafsma
    Golf 2 HProd
    Quote Originally Posted by shwah View Post
    My BHF setup:
    zero front toe
    Not knowing the track, the staggered camber means mostly heavy right hand turns correct? I have a track that coming up that is really hard on Left hand tires and another that is really hard on the rights. I have never staggered camber but think it might be a good idea for these tracks. Thoughts?
    Wheaton, IL
    1,893
    In most cases I end up using a left hand or right hand dominant setup. Based more on which corners are important, than on how many lefts or rights there are.
    Chris Schaafsma
    Golf 2 HProd
    Maybe a tiny bit of toe-in for the rears...
