Results 1 to 20 of 22
Thread: 2nd gen rx7 issues hot ....hot.....crappy looking coolant.
    Sep 2005
    BEAVER,PA
    273
    well, talked to Dave at KDRotary..... he is calling me this after noon and is sending someone 5 hrs to come and pick up the car......happy with Dave and Darrell (shop owners), not thrilled about this purchase....got to drive the car a total of 15-20 min..... should have done MUCH better homework. Atleast I have my trusty specmiata to run this weekend...... not a great return to IT racing. This car was wrecked at LimeRock and I have a feeling that there may have been some damage related to heat that may have not shown it head.... The car was then raced at Watkins without the undertray and or splitter.....the resevoir water looked like sh*t from day one. Like anything else I will just need to dump alot more into it....... I'll let you know what is the true problem when the guys tear into it. Thanks everyone.
    Greg Peluso
    Feb 2005
    Basking Ridge, NJ, USA
    267
    Dave is a straight up guy and absolute RX7 guru... hopefully youll be fixed up in no time!
    Jun 2001
    West Milford, NJ, USA
    241
    The time line of what occurred isn't completely clear - did the engine run ok last fall, but overheat when you 1st took it out this year? I've witnessed engine seals fail if they are stored over the winter without sufficient glycol - everything was fine in the fall, and then oil and water became one over the winter. Water in the engine freezes and expands, failing the main O rings.
    Dave Youngren
    NER ITA RX7 #71
    Asheville, NC US
    1,626
    It is always a good idea to store these cars with antifreeze in them. The cast iron will corrode quickly and let the seals move and they blow first time it comes up to temp. The area around the water jacket in some of these motors is .070 or less depending on core shift in casting. First put a pressure tester on the cooling system and see if it pushes AF into the chambers. Sniff tester(O2 sensor) on the open radiator cap with the motor running will find a leaking seal as well. If the car was designed to have a splitter and it is gone the low mounted oil cooler will not work. All the air is ducted with the splitter opening. Run the car with 200-220 water and never over 230 oil if you can. We run the factory 160 thermostat in all our cars.
    Worst case you will need one cast iron and a seal kit if everything else was as advertised. If you have the motor cracked open replace the apex seal springs. Don't give up, it will be worth a little headache when you get it right.
    Steve Eckerich
    ITS 18 Speedsource RX7
    ITR RX8 (under construction)
    Sep 2005
    BEAVER,PA
    273
    time line...
    i picked up the car in the fall and tried to run it an EMRA time trial event.....the water looked crappy then.. ran a 5 min session and saw water leaking from the rad area. I was upset that I pick up the car and it had isues....at the track I removed the resevoir and cleaned it out in hopes this was not coming from the engine....it was cold out and the car never got hot in 5 min.
    this winter the car was stored in a heated garage and started once a month.
    over the winter I replaced the spark plugs and oil due to the car flooding during one of the start ups.....the way the car is tuned , it is a bitch to keep running until it warms up.(Haltech system). I also fixed one of the hoses on the bottom of the rad.
    last week......took car to open lap day and experienced what I stated earlier.
    Conclusion.......car was messed up when I got it!
    Floyds Knobs, IN
    1,093
    Any news Greg?
    Chris Ludwig
    GL Lakes Div
    www.ludwigmotorsports.com
    Sep 2005
    BEAVER,PA
    273
    they picked up the car yesterday afternoon......5 hr drive so I'm hoping to hear from KD rotary tomorrow... and it would be nice to hear from the seller too. Thanks for asking Chris. I just talked to Matt over at Pirate Motorsports today and he did say you are the man when it comes to Haltech programming. Those guys run a RX8 in Grand Am.
    Greg
