Results 1 to 3 of 3
Thread: 87 Celica
    Jun 2002
    28
    Default 87 Celica
    I have an 87 Celica, 2.0L with 5 spd. Can anyone advise if there are LSD's made for this as well as the availibility of final drive gears? Thanks.
    Apr 2008
    Orlando, FL
    774
    From what I found your car could have a few different transmissions.
    It could have an E series that was shared with the mkII MR2 (with a differetn final drive), or it could have a S series transmission with a final drive ranging from car to car it was in.
    Depending on what you want there is factory options in the 4.3:1 range.
    Track Speed Motorsports
    [email protected]
    Jun 2002
    28
    I have now run into a problem I can't solve. I drove the car into my garage a few weeks ago to do some minor maintanence. Oil change, brakes, swap tires new battery, etc. It will not start anymore. Changed distributor, ecu, checked fuel pressure, spark good. It appears that the injectors are not getting the signal to start pumping fuel. Car will start if I blow in starter fluid. Definately a fuel / injector problem. I don't believe the injectors are getting the grounding signal. Does anyone have any ideas on what else I could check? Thanks in advance for your help.
    This is an 87 Celica with 2.0L 16 valve 3sfe motor with 5 speed trans.
