Results 1 to 5 of 5
Thread: Gen 2 Vert
    Oct 2009
    6
    Default Gen 2 Vert
    I just tore down my Gen 2 ITS RX7, and I was thinking about stuffing the suspension and a few other drive trane parts into a Gen 2 Vert. Should there be any difference that I should know of before I make a purchase?
    Canal Fulton, OH
    291
    Are you planning on running it in ITS as well? I think it would be a fun car to drive but it would suffer both aerodynamically and with the weight. As far as the suspension goes everything is the same. You will see an extra brace or 2 under the car around the trans crossmember.
    matt
    Aug 2005
    1,717
    Last time I read the GCR's only vert cars allowed in IT are cars specifically designed to be a vert. Since Rx-7's are coupes originally, then the vert's not classed in IT.
    edit....
    here it is, 9.3.1.8.f
    f. Convertible tops and attaching hardware shall be completely
    removed. Note: Convertible model cars are permitted if they
    were only available as convertibles (e.g. MG Midget), or if the
    convertible model is specifically allowed on the vehicle spec line.
    Convertible models may compete with their respective OEM
    hardtop. All latches shall be replaced with positive fasteners.
    Manual and electric sunroofs, original or aftermarket, where
    the panel is not normally removable shall be retained and run
    in the closed position. Components (motors, cables, rails) may
    be removed provided the panel is securely retained. Removable
    sunroof or T-top may be retained if bolted or welded in,
    or removed completely. Glass sunroofs must be removed. All
    sunroofs may be replaced with panel or replacement skin of
    the same material as the original surrounding roof material.
    STU BMW Z3 2.5liter
    Canal Fulton, OH
    291
    I definitely remember SCCA classifying the 2nd gen convertible in ITS. 2nd gen Convertibles are all over the place.
    matt
    Canal Fulton, OH
    291
    The convertible is in the GCR on the same spec line..
    matt
