Results 1 to 11 of 11
Thread: Fuel Cell filler location
    Feb 2010
    4
    Default Fuel Cell filler location
    I am installing a fuel cell in a ITA Miata, can I relocate the fuel filler cap or does it have to remain in the stock location?
    Thanks. -Richard
    Royal Oak, MI, USA
    1,599
    I'm not entirely sure if I understand... are you talking about can you use a remote fill valve or do you have to use the one on the cell?
    Either way - realize that it's financially and safety-wise in your best interests to use the fill cap on the cell. If you fit a remote one, there's need to fit all kinds of safety bits like check valves etc in case the hose is ripped off in an incident. Even so, it's still safer anyway to just not have bits that can rip off and spill copious amounts of gas. Instead, you can have a filler that's blocked off from the driver's compartment entirely.
    I'm going through this now on my DSR thanks to a legacy long filler neck from the FF I'm converting; makes me glad all over again that I didn't put one on my IT car...
    Vaughan Scott
    Detroit Region #280052
    '79 924 #77 ITB
    #65 Hidari Firefly P2
    www.vaughanscott.com
    Jan 2005
    Alachua, Florida
    261
    just curious why would you want to put a cell in a miata? the stock tank is in the perfect spot, low and in between th axles.
    Steve Elicati
    ITA 1994 Mazda Miata
    Central Florida Region
    Feb 2010
    4
    I am using the stock location (behind the front seats) the cell will sit higher than the stock tank and the filler hose will be almost horizontal. The option of using a filler cap on the cell directly
    Does not work due to its location (you would have to fill from inside the cockpit not very convenient during an enduro). I have seen MX5 in Koni with the fillers in the trunk (dry break), but I don’t know if that would be legal?
    -Richard
    291
    That would be ok, just make sure the entire assembly is seperated from the driver's compartment by a bulkhead or thick aluminum box. There's an ita civic for sale in the classifieds that has a nice looking set-up.
    Chris
    Unsquishable bug on the way!!!!!
    Nov 2005
    Jacksonville, FL
    734
    Yeah, remote fill/dry break is completely legal. The big caveat is that the filler has to be "flush with the body". Take a look at the pics of my setup and it might help you with some ideas.
    Christian
    Royal Oak, MI, USA
    1,599
    Don't forget that, at least in any enduro rules I've ever read/used, that the driver has to be out of the car when fueling anyway...
    Vaughan Scott
    '79 924 #77 ITB
    Jan 2002
    Somewhere in Upstate New York
    1,033
    Someone already started down that road, but I'll continue down it:
    "Why would anyone put a fuel cell in a Miata ?"
    Miata has probably the best located (for safety), best designed tanks of any production vehicle that is raced in IT.
    Any cell will be higher (bad), further rearward (bad bad) and unibody strength will be compromised by installation (bad bad bad...plasma cutters & sawzalls don't yield benefits in structural rigidity).
    Really.
    But that's just my opinion.
    Feb 2010
    4
    Christian
    Thanks for the info, by the way your Civic looks great.
    -Richard
    Nov 2005
    Jacksonville, FL
    734
    Quote Originally Posted by Richard.F View Post
    Christian
    -Richard
    Thanks!
    Jan 2010
    Houston-ish
    932
    Since original poster mentioned enduros, maybe he needs more tank capacity for longer driving stints? My 240SX only gets about an hour per tank of fuel at speed- that would suck for an enduro!
