Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Dl-1
    Dec 2007
    West Hurley, NY
    388
    Default Dl-1
    On another thread there was some talk about the usefulness of a DL-1 system.
    I searched and found a Vorshalg DL-1 data acqusition system. Is this what you guys were referring to? If so I have a question-- in addition to the box what do you need as far as sensors are concerned??
    Dan Deyo
    92 Acura Integra
    ITA #94
    Default Race Technology DL-1
    I'm sure the discussion was about the Race Technology DL-1, a GPS & Accelerometer based data acquisition system.
    http://race-technology.com/
    What sensors are useful with data acquisition systems depends on the questions you are trying to answer. You can measure vehicle and driver performance with the basic DL-1 without any additional sensors. But if you're trying to monitor your engine parameters, then having RPM, a temperature sensor and an oil pressure sensor might be useful. If you are looking at driver technique, then throttle position, steering, and maybe brake pressure would be helpful.
    Beyond that, what do you want to know? Suspension position? IR-tire temps? Airbox pressure?
    David Ferguson
    Veracity Racing Data
    http://veracitydata.com
    Dec 2007
    West Hurley, NY
    388
    Quote Originally Posted by David Ferguson View Post
    David Ferguson
    With only 3 years in SCCA seat time is key. I am told however that the addition of a DL-1 will enhance the learning. So I think at this time the basic stuff is what I need.
    Dan Deyo
    92 Acura Integra
    ITA #94
    Mar 2001
    Connecticut
    7,346
    You guys can also go in together and share a DL-1. All you'll need to do is buy a separate power cable (either a cig plug from Radio Shack or a pair of wires to hardwire it into your electrical system), and the proprietary plug that goes into the back of the DL-1. If you want to keep your GPS antenna permanently installed you'll need to buy one of those too (it's a magnetic base, but you may want to secure the wiring with tye-wraps and not bother with removing and replacing it between sessions when you're sharing).
    The basic DL-1 comes with a two-axis accelerometer and GPS inputs; this by itself is EXTREMELY powerful information, and a good basic setup. From there you an easily input RPM (same place you take it off for an aftermarket tach) and a brake input wire (run a wire from the ground side of the brake light switch to the DL-1 input so you can see when you touch the brakes.) Just by adding these two inputs you've nearly doubled its usefulness (and they're the easiest ones to do.) Best inputs after that are throttle position (if you have a TPS you can take it off there) and steering input (usually something like a rotary pot on the steering shaft or a linear pot on the tie rods).
    Then, when you become totally enamored with the product (and you will), you can add the DASH-3 display, giving you shift lights and input warnings.
    My preferred vendor for DL-1 products, and the guy through which I do my coaching/data acq work, is Jeremy Lucas of FastTech Limited. Plus he's an ITA competitor and an all-around good guy...
    http://www.fasttechlimited.com/
    GA
    Not my circus...not my monkeys...
    Dec 2007
    West Hurley, NY
    388
    Quote Originally Posted by Greg Amy View Post
    GA
    Thanks GA I will speak with Denise and come up with a plan.
    Dan Deyo
    92 Acura Integra
    ITA #94
    Apr 2003
    Sterling, VA
    734
    GA
    As somebody who DOESN't work for Jeremy, I have to agree with tGA statement. He is an awesome dude to deal with.
    Spanky | #73 ITA 1990 Honda Civic WDCR SOLD | #73 ITA 1995 Honda Civic WDCR in progress |
    ** Sponsored by J&L Automotive (703) 327-5239 | Engineered Services, Inc. http://www.EngineeredServices.com **
    Isaac Rules | Build Pictures
    Feb 2007
    292
    "I have yet to turn a wheel on track without improvement since starting to use the DL1 system." - Greg, SCCA National Driver
    Cool system! If it can make you Purple Crack fast on komho V700s, I am getting it!
    ______________
    Waterhaus Racing is Back!
    NRSCCA Competition Chair
    BOG Member
    "Nebraska organizing committees
    to race in Iowa & Ne board thing "
    Still working on a name...
    X-MVRG Member...
    ITB Rabbit/ITA Miata
    Apr 2008
    Orlando, FL
    774
    how would you rate a DL-1 system v.s. say a traqmate?
    Track Speed Motorsports
    [email protected]
    Mar 2001
    Connecticut
    7,346
    Quote Originally Posted by quadzjr View Post
    DL-1 has a distinct advantage in the Northeast, regardless of its technology: there are s**t-ton of folks up here using it. As such, you will learn scads more by comparing your data to others, and having local folks versed in how to read, interpret, and react to the data.
    GA
    Jan 2004
    Camas, WA
    531
    Said differently- use whatever is around you. in SFR tin tops, its mostly AIM data units, NE seesm to be DL-1.
    Marcus
    miller-motorsports.com - Its always an Adventure (and woefully outdated)
    1.6 ITE/SPU/ST2 Turbo Miata (in pieces... err progress)
    Feb 2003
    Grove City, OH, USA
    1,449
    If the title of this thread was 'data aquisition' instead of DL-1, I would offer the Race-Keeper data and Video acquisition system. Three axis accelerometer, GPS based, up to 4 camera inputs, 8 analog inputs, wireless dash display, 3D video capability and 15 minute installation without drilling holes.
    Just named Official Video Data system for World Challange for 2010, 2011, and 2012.
    www.race-keeper.com
    Bill Stevens - Mbr # 103106
    BnS Racing www.bnsracing.net
    92 ITA Saturn
    83 ITB Shelby Dodge Charger
    Sponsors - Race-Keeper Data/Video Aquisition Systems www.race-keeper.com
    Simpson Performance Products - simpsonraceproducts.com
    Nov 2005
    Jacksonville, FL
    734
    1st, everything tGA said is spot on. DL1 is some serious goodness and Jeremy Lucas is the MAN when it comes to data aq and data interpretation.
    I've had both. Started with the Traqmate and then "upgraded" to the DL-1. The Traqmate is, IMO, easier and faster to get started with but ultimately more limited. Less options on how to look at and interpret the data and there's no ability to add a DASH2 or DASH3 into the mix.
    Jun 2006
    Londonderry NH
    157
    I am in the northeast and have had an AIM Pista for three years and have yet to find anyone to share data to compare. If I had the resources I would buy the DL1 as everyone I talk to is running it!
    Jim Alley
    1990 ITA Miata
    Its all about doing your personal Best
    Aug 2005
    1,717
    I wonder how useful having the same system as everyone else is when no one has the same car as you do? Also, since the region owns one of the tracks we race there over 50% of our season, but this track is multi-configurable. So, when you get data you'd have to ask was that 13 cw, 13A cw, 13 ccw, or 13A ccw, or was that 14.... 15.... 16.... or 18.... so getting multiple sets of data for the same configuration can be problematic. Kind of reminds me of the time Greg was asking for data for Rusty's track in Iowa. Did you ever get any data for that track Greg?
    STU BMW Z3 2.5liter
  15. #15
    Mar 2002
    Black Rock, Ct
    9,594
    WHile he doesn't have the exact same car as everyone else, he's got the same motor as others, and he races on the same track. TONS of DL1 files on LRP.
    I'd get a DL1 from Jeremy if I were buying new here in the NE. Heck, he's been helpful to me, an early adopter AIM guy.
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
  16. #16
    May 2003
    Colchester, CT, USA
    2,120
    Quote Originally Posted by Z3_GoCar View Post
    It's still very, very helpful, especially when looking at someone faster.
    Dan, one thing to consider if buying one and sharing is that you guys will be on track at the same time. Used ones pop up once in awhile. You might even check in with Jeremy in case someone is upgrading.
    Jeff L
    ITA Miata
    2010 NARRC Champion
    2007 NERRC Championship, 2nd place
    2008 NARRC Championship, 2nd place
    2009 NARRC Championship, 2nd place
  17. #17
    Mar 2001
    Connecticut
    7,346
    Very. A data acq device is more than just something to spit out hard numbers for comparison, it's much more useful as a way to compare driving techniques and styles. Give me two files, one from an ITC car/driver and one from an ITR, and I'll make both drivers faster.
    Did you ever get any data for [Iowa] Greg?
    I did, but that situation was different: what I was looking for there was just a single lap so I could place track markers for the .LAP file for the DASH-2. That way the drivers had lap and sector times in the car during the first practice session... - GA
  18. #18
    Dec 2007
    West Hurley, NY
    388
    Good info, Thanks
    I will check this all out as a DA system seems to be a key area we have not yet become involved with.
    Although our cars are not used much the engine and suspension system is all Mazada so we can compare somewhat to others.
    Dan Deyo
    92 Acura Integra
    ITA #94
  19. #19
    Jan 2006
    219
    +1 to the "use what others in your class use".
    I have a DL1. While Traqmate seems to be prevalent in the SE, some very fast drivers with DL1 have shared data with me and its made me faster. I've also made myself faster with my own data. I almost wouldn't bother going on track without it. (edit: I mean in a test day. I don't think I've even looked down at my display during a hard race, but would probably rather not put wear and tear on the car on a test session without data, as I couldn't have quantitative evidence on what the changes to the car/driving did)
    If I was in SM, I'd have Traqmate as the majority of SM people I've seen use Traqmate.
    The other advantage of the DL1 is the ability to add the Dash2 system into your car, eliminating your gauges and all that crap in favor for a digital display.
    -Tom
    ITA Integra | 05 Mazda3 | 03 Mini
    http://www.tomhoppe.com
  20. #20
    Aug 2005
    1,717
    I don't know what other people are running in IT cars in So-Pac, a couple that I talked to, such as Darin and Naji are only running lap timers, but two features that I like about the Dl-1 is the accelerometer pack and the Rs-232 connection. I could hook my TecII up to the rs-232 and read the throttle position and rpm directly and log it. I could also hook all 4 wheel speed sensors up and get brake slide or wheel spin. Sounds to me that the only person I have to compare data with is myself at this point, so I can see the usefulness, but it's not as usefull as it could be to bring me up to speed.
    I have a friend who run an AIM system, but he drives a FC, so how useful would that data be?
    STU BMW Z3 2.5liter
