https://improvedtouring.com...ad.php?t=28436
If you want these topics combined (a good idea) let me know.
Combine away..makes sense to me.
Done...with adjusted topic subject. - GA
CPLUCKER > what were the results from gobblins go with the machined drums, or did you not survive? So, will I be protested next year for running iron drums since they were not OEM on a 240Z?
I used the drums at gobblins go, The results are pretty good, They did some "hot spot" bluing , but I have trouble with my brembo drums doing this anyway ( 2700 lb 280z ) but the press fit was really good and everything else seemed to work fine. we are making two small changes to the production run. The way the process to re-build them works we end up with a thicker steel liner so the weight is slightly higer, but the should be theoretically more heat tolerent.
So I am trying to get a run together of about 10 drums, the price will be $200 each plus return shipping to you. we only a few drums so you need to send a core drum to be rebuilt. The steel can be cracked or worn but the aluminum should be in good shape
so if you are interested
e-mail me at Chris.plucker at Areva.com
or contact Ross Schultz
at Titan Machine and Design
e-mail titan machine at yahoo.com
or call him 254-773-1110
send the cores to
2507 West Adams Avanue
Temple TX, 76504-3924
