Thanks guys. Scott (the NER CoT) is a reasonable man; after we talk to him I will post the results here.
Steve
Steve
Keep in mind Steve that the FIA spec for seat mounts requires side mounts of 5mm aluminum or eqivilent steel thickness and proper grade bolts. The hole in the spec is that you are free to put what you want in between the side mounts and the car as long as the proper fasteners are used. Many tech guys have an opinion about sliders, but not backed up in the rules.
Steve Eckerich
ITS 18 Speedsource RX7
ITR RX8 (under construction)
