Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: ITR Mustang
    Jul 2002
    Kings County, Nova Scotia, Canada
    11
    Default ITR Mustang
    Howdy All
    Looking at turning a recently aquired 95 Mustang into an ITR car for 2010.
    This is a V6 car, but would consider doing the V8 swap for 2011, for now just wanna make it safe and handle.
    Any advise on mustangs in ITR would be appreciated, I assume there is a few that have been built allready.
    Mainly looking for wheel, tire, brake and suspension tips.
    Thanks in advance.
    You know you have achieved greatness, when you are better than what everyone else thinks, but not quite as good as you think!
    Jul 2004
    Raleigh NC
    3,682
    The 1995 cars are classed in ITS, at a new attractive weight I might add.
    Ron
    Dec 2005
    Western New York
    159
    Default ITS Mustang
    Let me chime in here, and possibly answer a few questions.
    As noted, the '95 is classed in ITS. The '99-'02 is classed in ITR...but in both classes the allowed weight is probably WAY lower than physically achieveable, regardless of what components can be deleted, or replaced. Although I'm glad SCCA is approaching classification in IT with a plan in mind, this particular car is classed too light for reality. It probably should have ended up in ITA at a more realistic weight.
    Having had a few years experience with the Fox in ITB, I have thoughts on how to make the chassis work better, and eliminate some of the undesireable characteristics of its handling. Incidentally, I'm working on an ITR, which has parallel issues, and the weight sensitivity part, too (I don't expect to make anywhere close to the allowed weight). Therefore, what I'm saying is: You might want to be VERY judicious in adding any component that is not manditory for safety. Specifically, I'm thinking of Panhard Rod, or Watts Links, or added roll cage bars due to the added weight. Try to solve the problems with bushing selection (in the rear, very soft, or very mechanical), to reduce/eliminate the bushing-bind that is the source of the handling quirk.
    At the front, the same philosophy everyone else who uses struts, will apply to this chassis. Try to find hollow sway bars instead of solid bars.
    Cage: be very careful where the bars are located, and if you really need/want them. Tie into the chassis at the spring mounts in the rear, not the shock mount. In front, tie to the firewall where the upper frame extends off to the core support.
    Plan to remove any and every component allowed to lighten the car. Lose a few pounds, yourself (difficult, but possible...and allowed by the rules!!!).
    Happy holidays.
    Bill
    Bill Frieder
    MGP Racing
    Buffalo, New York
    Nov 2005
    Fort Mill, SC
    328
    Chris Dercole has one and he is on the board, it is a 99 and up though. His handle is RedMisted on here.
    1987 ITS RX-7
    2014 Ford Focus ST
    Currently borrowing tow vehicles!!
    Central Carolina Region
    STEELERS SIX PACK!!
    Jul 2002
    11
    Thanks Guys
    I've been talking with Chris and he's a wealth of info.
    Looks like I'll have to run 15" tires, yuk!
    stock size is 205/65x15, and looks to me like the only popular racing size is gonna be 225/50x15, this make sence to anyone?
    Any tips on strut manufacturer choice, even from the 79-94 guys?
    Nov 2005
    Fort Mill, SC
    328
    Quote Originally Posted by Jethro View Post
    Thanks Guys
    You can go to a 245/50/15 in the Hoosier. I would also suggest you talk with Sam Strano from Stranoparts. He is a wealth of knowledge when it comes to Fox Body Mustang setups.
    1987 ITS RX-7
    2014 Ford Focus ST
    STEELERS SIX PACK!!
    Dec 2005
    Western New York
    159
    Default ITS Mustang tips.
    ITR allows the cars to weigh a few pound more, so additional suspension parts may be more desireable, and less injurious to performance. For ITS, I'd think even more critically about added weight.
    Personally, I'm a fan of smaller wheel diameters with generous width, to reduce the rotational mass of the wheel assembly. Aftermarket/racing lists have 15's avaiable in various offsets. What you will have to pay for is lightness, not the size. Additionally, the handling can be enhanced by the placement of the lower A arm (smaller diameter wheel assemblies put the ball joint closer to the ground), giving you the opportunity to have an up-ward angled lower arm. This will give you enhanced camber change during bounce.
    Differential gear set ratios available (stock and aftermarket) for the 7 1/2 inch, are 3.08, 3.27, 3.4, 3.73, and 4.1. I prefer the lower gears with the second, third, and fourth transmission gears being used.
    What you want to concentrate on is how to enhance the handling without adding to the weight of the car. Aftermarket parts all weigh pounds and ounces...from which the car/engine combination cannot benefit. Hollow sway bars are available, too.
    Start your project with a through reading of the Mathias book on Mustangs ("chassis", actually number two). It will give you a grounding in the four link design, and its consequences. Solutions are proposed which work, but all add weight. There is one concept that is not in that book that will lessen/eliminate the problem. That is to replace the source of the problem (the rubber bushings), with spherical bushings. This is the major solution in the rear of the car. Peruse the AS sites also...they have delt with the problem for years, although their solutions are added mechanicals (weight).
    Good luck.
    Bill
    Bill Frieder
    MGP Racing
    Buffalo, New York
    May 2008
    Cleveland, OH
    327
    Bill:
    I really don't know about using 15" wheels on such a heavy car shod with horrible brakes. I use the airier 17" rims with all the brake tubing I can cram into the wheels. Our rotor sizes are 11"--pitiful by ITR standards. At tracks like Watkins Glens or Nelson, brakes are not a major issue so I guess you could run the smaller wheels. But at a Gingerman or a Beaverun, that brake pedal is gonna be down on the floor before you know it. I'd rather have the weight of the larger wheels knowing that my brakes are getting all the cooling possible.
    Another reason to optimize brake cooling: The ITR Mustang is equipped with PBR aluminum front calipers, unlike the earlier SN-95 cars that came with cast iron bits. This is great for weight, but these calipers deform like crazy in the heat, even at the easy tracks. It's normal for me to replace the front calipers (at about $65 a pop)about every other event. If I don't, I'll be wasting box after box of $200 brake pads. So running the larger wheels helps me to minimize an economic issue.
    Just my $.02
    Chris
    #91 ITR Mustang
    1st place-2008 Great Lakes Division Championship Series
    1st place-2009 Kryderacing Series
    Dec 2005
    Western New York
    159
    Default Mustang ITR
    Chris,
    I'm interested in the brake problems you experienced with the aluminum calipers. Did you see caliper deformation? Brake pads welded to the pistons? Was there evidence of boiled fluid (pedal to the floor, etc)? Did the seals turn to carbon? (I'm trying to think of all the brake-related problems we had with the 2.3 Liter ITB car.)
    Thanks for the input about the brakes. Your answers will make me reconsider the choices I have.
    Jethro is, of course, planning on ITS, which has mandated smaller wheel sizes, and lower weight. Also, supposedly, the engine has somewhat lower power potential in typical IT tune. All of which, may lower his threshhold of brake problems.
    Bill
    Bill Frieder
    MGP Racing
    Buffalo, New York
    May 2008
    Cleveland, OH
    327
    Bill:
    What happens with the PBR calipers is that they splay out, so that the brake pads begin to wear cock-eyed. This problem is very commonplace in the left front, and occasionally an issue on the other side unless racing at tracks with an abundance of left turns.
    It's also common for the piston sleeves to burn up. No, I've never had fluid boil to the point where I was literally hitting the floor. (Sorry if I exaggerated a bit.) But I've had to throw heel-and-toe downshifting out the window a few times because the pivot point would change enough to compromise throttle-blipping.
    The solution? Get as much air as you can to the rotors. Cut off the dust shields, mount the bigger wheels and run tubes no smaller than 3" in diameter. Use super hi-temp fluids and remember to bleed the fronts halfway through an event if racing at a brake-killer like Beaverun.
    Pads can make a difference with cooling. Unfortunately, I only have experience with Hawk Blues. I'm told that other companies, such as Carbotech (which I will be trying in '10), may have superior offerings.
    Brakes are the big operational weakness with these cars. I learned alot this past year about the need to baby my brakes, and to plan my race strategies accordingly.
    And although the bigger wheels hurt weight, you can mount wider rubber. A tradeoff, just like anything in racing.
    Hope this helps.
    Quote Originally Posted by billf View Post
    Chris,
    Bill
    Chris
    #91 ITR Mustang
    Jul 2004
    Raleigh NC
    3,682
    Quote Originally Posted by RedMisted View Post
    Very interesting discussion.
    I'm not sure I'm following everything though. You mentioned that you have heat problems and that the heat is deforming the calipers, but, then you say that you're not boiling the fluid. I'm assuming what you're experiencing is some fatigue and thermally induced stress relief, but, you'd need to get some pretty serious heat into it to do that. And that would boil your fluid.
    What you've described with your pedal feel is pretty much SOP for Z cars and many other ITS cars. And, it can typically be fixed with a serious analysis of brake ducting and cooling. You might have to switch to a new piston seal of that is having problems but the dust shield on the outside, well, those are going to get hard crumbly and fall away.
    What sort of rotor and caliper cooling do you have now? I assume you're using a air hat on the rotor that feeds air to both sides of the rotor and you've got a similar device mounted on the caliper itself. Since these are slotted rotors you might want to feed air into the center hub and skip the rotor hat.
    Anyhow, you should be able to make these brakes work and not experience heat problems. I've collected a lot of brake cooling setups over the years. Once I pick this Mustang up I'll have a look at the front area and might be able to offer some suggestions.
    May 2008
    Cleveland, OH
    327
    Ron:
    Serious, the combination of brake torque plus whatever heat does cause these calipers to deform. They are soft, crappy pieces. Lightweight as heck, but still soft and crappy. They splay out where the outer pad retaining "fingers" are located. Once this happens, the pads take a serious beating in localized areas.
    My cooling set-up is pretty basic: run a 3" tube to the inside of each rotor. I bought some brake spindle connections from Quantum Motorsports that allow me to run that size tube to the rotor, aimed not at the rotor center but just above. Perhaps not optimal, but after experiencing the limitations of the Mustang's brakes at Beaverun and Gingerman for the first time this past year, I'm thinking that some special pieces will need to be fabbed to get the air to a better location. And while using larger tubes...And more tubes... BTW, My intakes use the faux foglight locations to the max.
    You mentioned something about slotted rotors. I assume you meant vented unless I'm mistaken and the GCR now allows the use of true aftermarket racing rotors with surface cooling slots. The Mustang OE rotors are simple bald-faced bits, but vented.
    Yeah, when you have any ideas on this topic, I'd be eager to hear them!
    Happy holidays to all!
    Chris
    #91 ITR Mustang
    Jul 2004
    Raleigh NC
    3,682
    Yep, I meant vented.
    So there is no duct to the caliper itself? If not you'll need to correct that.
    I'm actually concerned that the caliper lacks the mechanical strength to handle repetitive braking forces that may not be heat related at all. But, with a modern OEM design and all the liability a manufacturer is burdened with I find that a bit hard to believe. I bet it'll be possible to figure out a solution for the problem.
    Jul 2004
    Raleigh NC
    3,682
    Hey Chris,
    What year is your car? I'll check around and see if there happen to be some casting differences or running part order changes. I know the books show the same part number for all years, but if you've messed with Fords any you'll often times find changes that didn't result in a part number of suffix change.
    Ron
  15. #15
    Jan 2004
    Camas, WA
    531
    Ron- talk to the T1 corvette guys, they have this problem all the time on the C5, which are similar calipers, no?
    Marcus
    miller-motorsports.com - Its always an Adventure (and woefully outdated)
    1.6 ITE/SPU/ST2 Turbo Miata (in pieces... err progress)
  16. #16
    Jul 2004
    Raleigh NC
    3,682
    Quote Originally Posted by Marcus Miller View Post
    As Chris mentioned they are PBR calipers and I think a similar caliper was used on the fronts of C4s if I'm not mistaken.
    I think this is the OEM sales sheet on those:
    http://www.pbr.com.au/downloads/broc...r_Brochure.pdf
    I imagine some discussion with PBR directly would result in some insight to the problem if it is indeed non-cooling related. I know that these same calipers are used on the front of Australian Roaring Forties GT40 replicas of which a few are used in sanctioned racing there. I know one of the guys really well and I don't recall them indicating they had caliper flex or failures, but I'll quiz him more directly about that.
  17. #17
    May 2008
    Cleveland, OH
    327
    The Quantum pieces only have a connection for a single tube to the rotor. So nothing for the caliper. I've known that it's critical to cool the binders as well. But let me ask, how might this be done given space limitations inside the wheel? I'm not that well-versed in brake cooling setups.
    You raise an interesting point, that the real problem with caliper splay may be more a function of material weakness under load, and not really a question of heat.
    My car was built in May, 1999. I put the month because there apparently are some differences, I don't know what, between early '99s and Mustangs manufactured later that year.
    Quote Originally Posted by Ron Earp View Post
    Chris
    #91 ITR Mustang
  18. #18
    Jul 2004
    Raleigh NC
    3,682
    Probably need to fabricate a manifold that will bolt onto the caliper and get air into the pad area as well as the outside housing. I made some for Jeff's TR8 and have seen others of similar design for the Z. Think about making it from sheet metal, or fiberglass as Mike M did for the Z, and having a 3" duct on the backside for the hose. The part that wraps around the housing will need to be thin if you're using stock wheels.
    One of the big reasons that folks got away from the smaller wheels on the Z was to get more brake cooling. Just having the wheel further away from the caliper assembly helped with airflow and also helps with packaging of cooling hardware. If you're sticking with the 15" wheels it may not be possible to get enough cooling in there and that might be part of the problem.
    And PBR might be able to help here as they should definitely have the data on what sorts of loads the caliper can handle. Something tells me that for a company like PBR that supplies damn near about everyone that the caliper itself can handle the load. And if it didn't at some point it time it was re-designed.
    And lastly, this might not mean anything but AutoZone lists two different part numbers for the driver's side front caliper depending on the year:
    1999 is this one and had a picture
    Part Number:
    C466
    2004 is this one and didn't have a picture
    Part Number:
    C898
    For the real story you'd have to go to Ford but in theory the 99-04 cars are the same car.
  19. #19
    May 2008
    Cleveland, OH
    327
    Ron:
    Thanks for checking on the calipers. The two part numbers at AutoZone probably doesn't mean a thing.
    If the calipers eventually show themselves to be truly substandard from a material/design standpoint, would we have any recourse with the powers that be to run anything else? For example, 13" Mustang Cobra brakes? (Geez, I wish!) Sure would help with durability (and heat).
    Interestingly, I hear that the A Sedan Mustangs were given allowances with their brakes because of severe overheating. Of course, those are much heavier cars travelling at much higher speeds.
    Part Number:
    C466
    Part Number:
    C898
    Chris
    #91 ITR Mustang
  20. #20
    Jul 2004
    Raleigh NC
    3,682
    Nope, choose another car.
    I don't have any position of power in IT land but alternative equipment is clearly not in the fundamentals of IT. If the brakes turn out to be non-workable, and I seriously doubt that will be the case, then that is, as they say, tough shit.
    I'm not discounting your observations on the brakes but there is much R&D to do before passing judgment on them. Early Z brakes didn't work well either until racers had done years of development to reach a tried and true formula.
