Results 1 to 13 of 13
Thread: Integra Setup?
Hybrid View
    Nov 2001
    Halifax, Nova Scotia
    639
    Default Integra Setup?
    I'm working on getting this 94 Integra to turn. It still understeers, even though I've unhooked the front sway bar, softened the front shocks & stiffened the rear shocks. Any of you Integra guys willing to share your setup? This car has 550F 850R with a 19mm rear bar.
    Alignment settings? you may be running out of front suspension travel with no front bar and actually making the car worse.
    Nov 2004
    CT
    982
    You will need MUCH more rear swaybar. If the car still will not rotate then look to adjust the rear toe and/or rear tire pressures. Is this a race car? If so those springs rates are too low.
    Jeremy Billiel
    Nov 2005
    Jacksonville, FL
    734
    What they said ^^^^
    More spring at both ends, more rear spring bias, more rear bar, more rear pressure.
    Nov 2001
    Columbus, OH
    1,522
    1 - Hook your front sway bar back up before you start blowing axles.
    2 - Increase both of your spring rates a lot; like, 35-50%.
    3 - Get a real man's rear sway bar. My rusty '91 crapbox I drive on the streets has a 19mm on it.
    Kevin
    2010 FP Runoffs & Super Sweep Champion
    2010 ITB ARRC Champion
    2008 & 2009 ITA ARRC Champion
    '90 FP Acura Integra RS
    '92 ITA Acura Integra RS
    '92 ITB Honda Civic DX
    Nov 2001
    639
    Yeah, this is a track only race car. I have a set of #700's sitting on the shelf. Good for the front I think. So what you are saying is at least #1000 for the rear? I cant find anything bigger than 21mm for the rear. OK?
