Results 1 to 20 of 20
Thread: 4.77 gear for 1.8 miata?
    Quote Originally Posted by RacerBowie View Post
    Would almost certainly be too much gear for Daytona and Roebling. Don't know about Sebring.
    Clarification: While you won't run out of 5th gear at Roebling, a short final drive makes you shift more, and in more awkward places there. I slowed down by over a second when I tried my 4.88 there, versus my 4.30 in my 1.6 Miata. I think a 4.1 would be GREAT at Roebling.
    agreed... the 4:77 (s2000?????) and/or 4:88 are way too much for a 1.8. my car uses a 4:30 that's good at MOST tracks.
    the biggest thing you need to consider is just how much extra gear you need out of a given corner. for example my 4:30 works fine for exiting most corners. i never find myself shifting in awkward places yet some tracks i could use a BIT steeper gear but in only one corner or two. is the change worth it? to go to a 4:44 would make sense but to jump to a 4:88 is a day and night difference.
    most guys who used to run rotarys make the assumption that you use as steep of a gear as possible, since you'll be revving the ever living daylights out of the motor. not in a 1.8 miata.
    suggestion. try a 4:30. since last year of using the 4:10 i've noticed a big difference and since it's an oem ratio in the 99+ cars, you can get center sections all ready set up with the torsen limited slip.
    check our link and we'll see what we can do for you.
    Jan 2005
    Alachua, Florida
    261
    Quote Originally Posted by mazdagt3 View Post
    Thanks 4.3 was my other choice.
    Steve Elicati
    ITA 1994 Mazda Miata
    Central Florida Region
    Nov 2009
    12
    <snip>
    I too was wondering about this approach. I think it is a good possibility, but I have one reservation. I've never race a Torsion, but I've heard it said that if one pounds a curb and loses traction on an inside rear tire, then the Torsion will break lock and not recover until the torque on that wheel drops. Any experience or opinion on that question?
    Jun 2001
    Hickory NC USA
    233
    After racing a 1.8 SM for two years I can say with much certainty that a 4.1 is not optimal on any of our tracks here in the SE. You want at aleast a 4.3 on any of the tracks we race in the SE I would think. You would want to go to a 4.77 at RA as it is straight drag race out of turn 7. Maybe even the same at VIR because of Oak Tree.
    I agree with Bowie that with Roeblings long sweeping corners where you have to be smooth, you probably want a taller gear, but I still think that 4.1 is a little too tall. I have raced against a similarly prepped 1.8 with a 4.3 and the difference was noticable.
    Derek Ketchie SEDiv
    Jan 2005
    Alachua, Florida
    261
    Thanks for all the input guys. I guess I'm searching for a 4.3 r&p.
    Steve Elicati
    Sep 2010
    Kingwood , Texas
    153
    Bringing this back from the dead :
    I currently have a 4.1 Torsen in my 95 ITA Miata , running a Stahl header that makes good HP up top , but gives up some TQ down low ... We're adding a MSPNP and Louie R is tuning this week help that.
    My primary tracks are TWS 2.9 CCW , MSRH CW , MSRH CW
    The 4.1 is terrible @ MSRH CW
    The 4.1 is less terrible @ MSRH CCW
    The 4.1 is less than perfect @ TWS 2.9 CCW
    I've heard many conflicting opinions about which gear , but we all agree the 4.1 is less than optimal
    Any other thoughts ?
    May 2010
    Dayton, OH
    98
    I bought my 1.6 with a 4.10 and hated it! I was always above or below my power band in the corners and I ALWAYS got my butt kicked on the start. I switched to a 4.77 (Kia Sportage R&P), Megasquirt, and upgraded the header. It completely transformed the car!
    Granted, it's a 1.6 and the MiDiv tracks I race are shorter and more technical. I shift a lot more but I've learned to adjust. My times have really improved and I'm getting podium finishes.
    Don't forget there's a 4.44 R&P out there to.
    Oct 2003
    Greensboro, NC
    517
    Have I read everything correctly... if I have a 1.6 and want to change from the 4.3 to a 4.44, I can find a R&P from a 1st gen Rx7? I usually find myself at VIR or CMS, I think the 4.44 should help keep the rpms up in the slow corners.
    Thanks in advance!
    hoop
    Greensboro, NC
    STL Newbie
