How do you guys vent your overflows? Our biggest issue with stumbling on track right now is a temporary rich condition we are getting on one carb in hard right hand turns, but only after the car has been on track for 4-5 laps. We have vented the bowl overflows back into the air cleaner, and I think when the bowls heat up we are overflowing back into one of the carbs (rear) in the hard righthanders causing the problem. Is it a mistake to vent the overflows back into the filter housing? As for the needles/oils/springs we intend on spending some dyno time experimenting with different combinations. We still have yet to get O2 sensors into the exhaust to get better mixture info, so that will help tune it too. Really it mostly ran very well, but the main problem was it "richening" out in those hard corners. We smooth that out, and our laptimes should be just 3-4 secs off the pace with an undeveloped car and driver. Thank you again everybody. I really appreciate everything the community on the forum has to offer.
Chris Carey
Central Florida Region
ITS/Vintage Datsun 240Z
Favorite tool to remove undercoating---- A curb!
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
