Results 1 to 4 of 4
Thread: Competition Valve Jobs
    Jul 2001
    Chicago, IL
    253
    Default Competition Valve Jobs
    If a cylinder head had a 3 or 5 angle valve cut can you tell by looking? is it physically apparent? thanks
    Easier to tell by looking at the valve, but yes.
    Jul 2001
    Chicago, IL
    253
    Thanks - yes I meant the valve/head assembly. I assume you would see sharp angles/edges versus a rounded slope on the topside valve edge? anything else to look for? thanks
    Jul 2002
    48
    You can really only "see" it at the time the work is done. After the engine has run, not so easy to see. 3 of the angles are to set the seat "width" and postion. The outer two angles from the seat just help to "mold" the flow. The machine shop will use blueing to see how his angles are shaping up as the seats are ground.
