i guess my basic take on all of this is that if the CRB is going to "trump" the ITAC and its recommendations, they should have a detailed rationale that amounts to something more definitive than "because......."
and when it comes to "passing the sniff test" portion of this, it does not look good if a CRB member has a car that appears to be very close to or less than the "process" weight and the CRB then tells others that they cannot have the process weight or needs 200#'s more (or 196#'s more in my case). and yes i am taking literary license is stating what they said inasmuch as it is actions or lack of actions that seem to be speaking and being interpreted.
ray, fwiw, i thought you were pulling away from me very much like the 2002's at mid-ohio a couple of years ago and you were not quite as good in the corners as i recall. i don't think some were as good in the turns (e.g., T1) as i was but honestly i chalked most of that up to it being many folks first time at mid-ohio for the IT Fest.
it was the classic power vs. handling trade-off in my opinion.
