Results 1 to 20 of 34
Thread: More 240z Suspension Questions
    Atlanta, Ga
    631
    Thanks Paul.
    I finally scraped the rust off in enough places and found the weight markings on the springs.
    375 front (hyperco) 300 rear (carrera).
    I was thinking of testing with 350f/275r and 375f/275r and then 375f/300r like it is now. Keith ran 400/350 at one point but that was with RR shocks. He won the ARRC with Bilstein's and 350/285. I dunno who makes 285 lb springs, maybe Carrera did at one point.
    Thanks again to all who posted.
    Tom
    Jul 2004
    Decatur , GA, USA
    183
    Paul-
    Sorry, but I don't understand your point about choosing your spring length to "center your shock travel". Once you choose your shock brand and length, and decide on your ride height, the shock "center" is going to be wherever it ends up, based on the shock length and the dimensions of your specific car. Seems to me that no matter what length spring you use, the shock rod will end up in the exactly the same place relative to the shock body, unless you change the ride height. The only thing that will change is how high the lower spring mount sits. Or am I missing something? I realize you want to not end up with the shock near either end of its travel (particularly compression), but I don't see how spring length enters into the equation, except as it may limit your ability to set the car at the desired ride height.
    Tom Lyttle
    Decatur, GA
    Trussville, Alabama, USA
    1,087
    Reference: Carol Smith....changing spring length changes the natural frequency of the spring. If you get the natural frequencies off front to rear, strange things happen. Chuck
    Chuck Baader
    White EP BMW M-Techniq
    Nov 2005
    Rocket City, Alabama
    607
    Hey Tom,
    If you section the strut tube correctly on the Z you can move the shock up and down in the tube using different length spacers in the bottom of the tube. Of course that assumes you are using a shock that is shorter than OEM that gives you the dampening you want. You have about 1-1.5" to play with. That way you can center the shock while getting the ride height you need. At least it worked that way for me.
    In the back, you have even more to play with since you leave the tubes a little longer when sectioning.
    Paul
    Paul Ballance
    ITS '72
    1972 240Z
    Atlanta, Ga
    631
    Quote Originally Posted by chuck baader View Post
    So a 12" spring would act differently than an 8" spring. Right? So how does more or less free travel change things?
    And Paul, its not so much that the shocks need adjusted around, I was just thinking of going to either 8, 10 or 12 inch springs all around.
    To make it easier to change things without re-scaling the car. But if there is an advantage to longer in front, say, smoother transitioning / less twitchy and shorter in the rear, (why, I dunno), then I shouldn't change the results of prior testing. I know my driving style isn't like the former owner. Larry Stepp liked a stiffer suspension if I remember right. His BMW was stiffer than Chet's. But Chet ran the ARRC in the 240 with 400/350 f/r. So, like I said, I dunno.
    Atlanta, Ga
    631
    Of course, maybe I should quit thinking so much and just shut up and drive.
    1,087
    Two identically built cars will usually use two different sets of springs and bars. Read Carol Smith's book and he explains the relationships. That is way advanced and over my head...I just changed and lucked out to get the balance very good front to rear. I finally am just driving. Chuck
    Chuck Baader
    Jul 2004
    Decatur , GA, USA
    183
    Paul -
    I realize you can move the center of travel a bit by adjusting strut tube length and the size of the spacer (or not using one) under the insert. I just don't see how that is influenced in any way by the length of springs you use, which was the original question. Or was I reading to much into your response - that centering the shock is a good thing in general (and you weren't addressing the spring length question?)
    Tom Lyttle
    Decatur, GA
    Aug 2002
    Plantation, Florida, USA
    14
    Good Day folks,
    My two cents on this topic real quick. First off, a coil spring is only considered 36% unsprung weight, so buying an IT spring with this as the main criteria might not be that great. Some people think a longer spring produces more reliable results. I like trying to use the same size springs so that I'll have more choices to change my chassis setup. Once the front tubes are sectioned, changing the shock body length and shimming up and down inside the tube could only change your droop travel since the top of the strut and the bump stop will not change location. Once you get the components in the right location at your normal ride hide, you shouldn't have to change it that much. We use 10's and 12's I believe and incorporate a 2" space sometimes.
    Hope this helps.
    greg ira
