Ok Tom, I checked my notes and you should shoot for shock travel, for Bilstein, 2 3/4" - 3" bump and 2 1/2"-2 3/4" rebound. So roughly 5 1/2" total travel.
I did assemble my suspension and check travel and wound up getting 10" springs. That sounds long but I now have plenty of adjustment and when I re did the coilovers I changed the upper hat and put in camber plates. Needed the longer springs to make it work out right.
Of course, if we are at the point of weighing springs for their "unsprung" weight then I assume we have a 10/10ths build and that the driver will notice the difference.
In my car, I know that isn't the case. The driver is doing good to show up.
Paul Ballance
ITS '72
1972 240Z
Thanks Paul.
I finally scraped the rust off in enough places and found the weight markings on the springs.
375 front (hyperco) 300 rear (carrera).
I was thinking of testing with 350f/275r and 375f/275r and then 375f/300r like it is now. Keith ran 400/350 at one point but that was with RR shocks. He won the ARRC with Bilstein's and 350/285. I dunno who makes 285 lb springs, maybe Carrera did at one point.
Thanks again to all who posted.
Tom
Paul-
Sorry, but I don't understand your point about choosing your spring length to "center your shock travel". Once you choose your shock brand and length, and decide on your ride height, the shock "center" is going to be wherever it ends up, based on the shock length and the dimensions of your specific car. Seems to me that no matter what length spring you use, the shock rod will end up in the exactly the same place relative to the shock body, unless you change the ride height. The only thing that will change is how high the lower spring mount sits. Or am I missing something? I realize you want to not end up with the shock near either end of its travel (particularly compression), but I don't see how spring length enters into the equation, except as it may limit your ability to set the car at the desired ride height.
Tom Lyttle
Decatur, GA
Reference: Carol Smith....changing spring length changes the natural frequency of the spring. If you get the natural frequencies off front to rear, strange things happen. Chuck
Chuck Baader
White EP BMW M-Techniq
Hey Tom,
If you section the strut tube correctly on the Z you can move the shock up and down in the tube using different length spacers in the bottom of the tube. Of course that assumes you are using a shock that is shorter than OEM that gives you the dampening you want. You have about 1-1.5" to play with. That way you can center the shock while getting the ride height you need. At least it worked that way for me.
In the back, you have even more to play with since you leave the tubes a little longer when sectioning.
Paul
Paul Ballance
ITS '72
1972 240Z
So a 12" spring would act differently than an 8" spring. Right? So how does more or less free travel change things?
And Paul, its not so much that the shocks need adjusted around, I was just thinking of going to either 8, 10 or 12 inch springs all around.
To make it easier to change things without re-scaling the car. But if there is an advantage to longer in front, say, smoother transitioning / less twitchy and shorter in the rear, (why, I dunno), then I shouldn't change the results of prior testing. I know my driving style isn't like the former owner. Larry Stepp liked a stiffer suspension if I remember right. His BMW was stiffer than Chet's. But Chet ran the ARRC in the 240 with 400/350 f/r. So, like I said, I dunno.
Of course, maybe I should quit thinking so much and just shut up and drive.
