Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Trunk panel rules?
  1. #21
    Aug 2009
    8
  2. #22
    Jul 2009
    21
    the challenge with the 850 will be making weight.
    we have 300 pounds to go, I can easily see another 100-125 pounds. The other may come from creativity and choosing the right parts.
    Or the driver losing some weight
  3. #23
    Nov 2005
    Jacksonville, FL
    734
    Quote Originally Posted by Tuff240 View Post
    We put some old 225/50-15's from our Volvo 240's on it for the Novice day. They are 4 years old... lol.
    We are limited to a 15x7 wheel, so 245 may be the limit.
    I doubt we will be able to get to minimum weight.
    I doubt it will be challenging for wins in ITS. The 240Z's have quite a bit of time on us. We'll see how it goes. We are hopeful, but also realistic.
    Gotcha. FWIW, you might try and test fit the 275's... D-Stock autox guys are shoehorning them onto 6" wide wheels so they should work (relatively) OK on a 7" wheel. I'm not saying it'd be ideal but it may help keep the car from overheating the front tires.
    Yeah, minimum weight was one of the concerns I had about the car. Those things definitely have some tank like build quality!
    Even if the 850 is never "the" car to have, it's definitely one of the coolest/quirkiest cars for the class. Best of luck with the two builds!
  4. #24
    Jul 2009
    21
    I think we can get it within 150 pounds with little work. The next 150 pounds will take some creativity good thing we have a few months to figure that out
  5. #25
    Aug 2009
    8
    I painted the wagon last weekend...
