Results 1 to 15 of 15
Thread: 4.12's again
    Purcellville, VA USA
    902
    Default 4.12's again
    Ok Neon racers. If the 4.12 final drives were available again, who would be interested?
    email or call me.
    Chris "The Cat Killer" Childs
    Angry Sheep Motorsports
    810 417 7777
    angrysheepmotorsports.com
    IT,SM,SS,Touring, and Super Touring
    Mar 2007
    134
    Price still in the $800 range? I have a 98 200SX thats putting about a car length and a half on me on a 1/2 mile straight.
    Victory at all costs, you know...
    Big C- just ignore this thread, OK?:cool:
    Jim Barnsley, Streetwise Service
    WCMA IT2 Neon Twincam
    2009/2010 Regional and Alberta IT2 Champion
    2009 Regional Overall Champion. Second this year, dammit.
    902
    It would be in the $500 range for the parts. Installed around $800+ small parts.
    If I know that I have enough interest I can get them down around $400 for the ring gear and output shaft.
    I detroyed mine at sebring in Jan and was getting clobbered at the IT Fest this year without it.
    810 417 7777
    Aug 2005
    Andover, KS
    121
    Quote Originally Posted by Rabbit07 View Post
    email or call me.
    Count me in Chris. For 1, mebbee 2.....
    I was wondering what happened to you at IT Fest....
    Paul Sherman
    Wichita Region
    '96 Neon #19 ITA (finally )
    Formerly known as P Sherm
    Joined 30 Sep 02
    Member No. 1176
    Nov 2005
    Fort Mill, SC
    328
    I would be interested as well. What all parts need to be changed? Just output shaft and ring and pinion?
    1987 ITS RX-7
    2014 Ford Focus ST
    Currently borrowing tow vehicles!!
    Central Carolina Region
    STEELERS SIX PACK!!
    902
    The Ouput shaft from Mopar comes with 1/2 syncro assembly aswell as the gear cluster. The Output shafts as I get them are just the Pinion so to speak. You need a 20 ton press and some heat to remove 5th,4th, and 3rd from the output. Then there are some roller bearings that also may need to be replaced.
    810 417 7777
    Aug 2005
    Andover, KS
    121
    Chris, have you looked into any custom FD gear sets, like a 4.30 or lower?
    Paul Sherman
    Wichita Region
    Joined 30 Sep 02
    Member No. 1176
    902
    Quote Originally Posted by PSherm View Post
    Yes I have, and you wouldn't like the price!?!? NVG wanted engineering time to create them. A 4.30 would still allow top speed @ Daytona without an issue. Most tracks our top speed is around 120ish, so even a 4.5 would be a good choice. Custom Final drives ring the bell around 2K
    810 417 7777
    Aug 2005
    Andover, KS
    121
    Yikes! I'm still tempted to try the 3.55 trans. It would mean using 2nd more, but so many corners I'm between 2nd and 3rd gears on exit w/the 3.94.
    So what happened at ITFest? I was hoping to see the Neon near the top of the results. I reeeeeeally wanted to be there, but being unemployed since Feb has killed my season completely. Might be back to work soon though, so I might be able to salvage it a bit. Would love to be able to do the ARRC.....
    Paul Sherman
    Wichita Region
    Joined 30 Sep 02
    Member No. 1176
    902
    Well, I could be all full of BS about how I missed my tire pressures and the align,ment was off, but that would be a lie.
    Truths;
    1) I was not in the right place mentally. I hadn't driven the Neon since Jan @ Sebring and was pissed off @ the car. Also, I found my self not taking chances due to my new little guy that I now need to provide for.
    2) Car was short the 4.12. I know that it is only about a 6% difference in ratio, but man it helps!
    3) Car has engine # 4 or 5 @ this point and was not quite broken in yet.
    4) I was in survival mode to just get through the weekend. I actually needed to get a waiver this year due to 3 DNF's last year.
    5) The development of the Neon has been on hold due to work getting in the way of racing. Even when racing is my work. There are still some items left on the table. Not much time in them, but I am sure they will help.
    I plan to attend the ARRC this year if all goes well @ the RunOffs. We'll see if I can find some speed between now and then.
    810 417 7777
    Oct 2005
    2
    Well, Chris, if you need work done on the Neon, you have my number and I can work on that while your "working"
    Greg
    96 Plymouth ACR, FSP
    97 Dodge ACR, SF
    Feb 2003
    Orlando, Fl
    193
    99.999% here!!!!!!!!! I'm in!!
    Chris Leone
    318i going STL!!!
    E36 ITS underconstruction(sold)
    84 944 ITS (sold)
    71 240z more than half way there/now GT2 bound!!
    ChrisLeonemotorsports.com
    Roll cages and fabrication
    902
    I sent the PO today.
    If interested, please call me or email me to make payment arrangements
    Thanks!
    810 417 7777
    902
    Parts arrived today. I will be contacting those who showed interest. If there is anyone else please let me know. I have 10 pieces in hand.
    810 417 7777
  15. #15
    Nov 2005
    Fort Mill, SC
    328
    Chris, so how did the $$ shake out, were you able to get down in the $400 range.
    1987 ITS RX-7
    2014 Ford Focus ST
    STEELERS SIX PACK!!
