Results 1 to 14 of 14
Thread: Koni Strut Failure?
    Nov 2005
    Fort Mill, SC
    328
    Default Koni Strut Failure?
    Well I have all 4 Koni yellows off the car for the install of my GC kit. The rears are still stock valving and compression seems to be pretty equal.
    The fronts I had Truechoice rebuild/revalve over the winter. They have 1 double regional, a 1 hour enduro and 5 autocross runs on them since rebuild. On one of them I am able to push the rod into the strut and it rebounds. The other I can barely get it to compress. Both of them are set to full soft while doing this. The units were revalved with 380/lbs being the minimum spring rate.
    So the question is is the one I can compress blown out again after very little track time or is the stiffer one having some other kind of issues.
    FYI the one that is easy to compress was on the RF which was only loaded on 2 turns roughly at Beaverun. The stiffer one would have seen the majority of the load.
    1987 ITS RX-7
    2014 Ford Focus ST
    Currently borrowing tow vehicles!!
    Central Carolina Region
    STEELERS SIX PACK!!
    Jan 2008
    North Olmsted, Ohio
    519
    Hey Chris,
    I have the same set-up from Truchoice.
    Mine have been fine so far.
    But my spring rates are A LOT stiffer than yours.
    600# front and 800# rear.
    But a civic and a neon are 2 totally different cars!!
    This whole suspension is new to me and I dont know a lot about it. I hope I dont have any problems anytime soon!
    take it easy
    Greg Vandersluis
    #4 1990 Honda Civic Si
    #97 2003 Chevrolet Corvette Z06
    #93 2006 Ford Mustang
    Carbotech/BFGoodrich/Vandersluis Motorsports
    2010 Great Lakes Division ITA Champion
    2012 Great Lakes Division T1 Champion
    Jul 2006
    Sunnyside, NY
    1,197
    Sorry about the Koni shock - sounds like you should take it back to truchoice. I have the Koni Single adj. SPSS3 with rally tarmac spec springs w/ no problems.
    (Thread hijack...)
    ITA_Honda - what kind of Civic? I have an 92 EG si.
    Demetrius Mossaidis aka 'Mickey' #12 ITA NESCCA
    '92 Honda Civic Si
    STFU and "Then write a letter. www.crbscca.com"
    2013 ITA NARRC Champion and I have not raced since.
    Jan 2008
    North Olmsted, Ohio
    519
    Quote Originally Posted by mossaidis View Post
    (Thread hijack...)
    Im rockin the 1990 Civic Si hatchback. lol
    Greg Vandersluis
    Nov 2005
    Fort Mill, SC
    328
    Quote Originally Posted by ITA_honda View Post
    Greg did you run the IT fest?
    1987 ITS RX-7
    2014 Ford Focus ST
    STEELERS SIX PACK!!
    Jul 2006
    Sunnyside, NY
    1,197
    So cute!!! Having the EF explains the spring rate difference!
    '92 Honda Civic Si
    Jan 2008
    North Olmsted, Ohio
    519
    Quote Originally Posted by cjb25hs View Post
    Chris- yes I did run the IT fest and what an event! You really need to go next year. There were 25 ITA cars that started Saturday. I qualified 19 out of 25. The guys that come there are unbelieveable! Joe Moser set a 1:40.2 on the pro course..and Im pretty sure he beat the track record. My fastest was a 1:47.2
    So yeah, a bit of difference there.
    Races were 20 laps each day so there was plenty of track time. I had a race long battle with the #9 Colletti Motorsports Acura Integra driven by Cincy RE Bill Niemeyer. We switched positions atleast 3 times if I remember right. It all came down with 2 laps to go where I broke my left rear hub in Turn 3 which almost flipped the car on its roof. Spectators on the keyhole hill said my rear end was 4 feet in the air, spun around a few times and landed in the sand trap.
    My weekend was done. But atleast I was ok and no one else was involved.
    Greg Vandersluis
    Nov 2005
    Fort Mill, SC
    328
    Wow sounds like you might have had to clean your shorts out after that. Well I am boxing up the front struts and sending them off to Truechoice to be checked out.
    1987 ITS RX-7
    2014 Ford Focus ST
    STEELERS SIX PACK!!
    Jan 2008
    North Olmsted, Ohio
    519
    that happened so damn fast I didnt even have time to crap myself! LMAO
    Greg Vandersluis
    Mar 2002
    Black Rock, Ct
    9,594
    sounds like a rod might be bent...check the side loading etc etc, etc.
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
    Jan 2008
    North Olmsted, Ohio
    519
    We have it at a collision center and they are going to put it on their frame machine just to check and make sure everything is ok.
    We were inspecting all the suspension components and such and didnt really see anything out of the ordinary.....
    but we took it there just to be sure...
    Greg Vandersluis
    Jan 2008
    North Olmsted, Ohio
    519
    what spring rates are you running?
    Greg Vandersluis
    Jul 2006
    Sunnyside, NY
    1,197
    Spring rates right out off DMS' web site (well almost) 750/450. I should go 800/500 but not until the driver feels maxed out in ability.
    '92 Honda Civic Si
    Jan 2008
    North Olmsted, Ohio
    519
    Haha I hear you on that.
    I ran stock spring rates last year (250#) all the way around.
    Yuck. lol.
    Now this year changing to the 600#/800# HOLY CRAP. lol.
    Especially at Mid-Ohio the rear starts kicking out. Its a handful but in a good way. I kept telling myself.. "So this is what a handling car feels like" "ohh the rear end rotates nicely now, i see"
    lol.
    Greg Vandersluis
