Results 1 to 10 of 10
Thread: Mk4 Q
    291
    Default Mk4 Q
    Anybody know whats involved in removing the secondary air injection (SAI) pump and the evaporative emissions (EVAP) system on a 2.0 car? Obviously I don't car about check engine lights, but performance is a must. Would I be able to tune it out with VAG-COM or the MegaSqurt system?
    Chris
    Unsquishable bug on the way!!!!!
    Aug 2006
    146
    Default You building one?
    I am sure the megasquirt will work. The Lugtronic will work and is specifically designed for the VW... it is based upon the megasquirt but customized for VW. If it is an IT build then you can get it with the Lugtronic with wireharness etc. or with a plug that plugs into the factory wire harness.
    Are you building one?
    I have one waiting to be built. Right now I am just driving it on the street as a backup car.
    Beran Peter
    ITB #0 NER
    VW Golf
    Oct 2006
    Melbourne, FL
    131
    Absolutely it could be done with a Megasquirt however stick with the early Mk 4's as the later one's (01 02??) are drive by wire which MS cannot handle (nor can lugtronic if I am not mistaken)
    Jeff Linfert
    Atlantic Auto Works
    We Install and Tune Megasquirt Systems
    #97 GTL Scirocco (for sale)
    ABA Corrado powered by MS3. 40+ MPG
    291
    It's an early one, 98 NB to be exact.
    Chris
    Oct 2006
    Melbourne, FL
    131
    Very doable. The AEG should be capable of about 125whp in IT trim with a good tune on a Megasquirt.
    Jeff Linfert
    Atlantic Auto Works
    291
    that's good numbers, seeing as it's gonna be in ITC
    Chris
    Aug 2006
    146
    Default Itb
    ITB
    VW Golf 2.0l 99-03 is in ITB
    Beran Peter
    ITB #0 NER
    VW Golf
    Oct 2006
    Melbourne, FL
    131
    Quote Originally Posted by Beran View Post
    ITB
    He's talking about doing a new Beetle which is an ITC car.
    Jeff Linfert
    Atlantic Auto Works
    Oct 2006
    Melbourne, FL
    131
    Chris, DO NOT waste your money on a Lugtronic system. For a couple of hundred bux more than the Lugtronic ECU I can sell you a Megasquirt 2 system installed AND tuned.
    Jeff Linfert
    Atlantic Auto Works
    291
    You gonna come over here and do the work? You can pm me or email details nismo92 at hotmail dot com.
    Chris
