The 1.8 goes best with the deck at 15 off and the PTW # @ 004. Gapless rings and it will fly. It will come out vey close to the . 5 compression add.
I have not seen many stock bore engines that are unusable. I get them setup per above #s. The required hone is usually about 1.5 on a high mile engine. If the thrust bearings, are good, the bore will be good. IMHO, of 50 or so race VW engines. MM
