Results 1 to 3 of 3
Thread: 103db at LRP
    Sep 2008
    Weare, NH
    483
    Default 103db at LRP
    I haven't raced at Limerock since I had the 928 so I
    was wondering about sound....
    where / which side is it normally measured on?
    While 103 is twice as loud as the 100 we blow regularly
    at NHMS, is the distance/config different enough to
    make it of comparable difficulty meeting?
    TIA
    Glenn
    Glenn Lawton
    GSMmotorsports
    #14 ITS RX7
    NARRC ITS Champion 2012
    NERRC ITS Champion 2013 12 11 10 09 08
    NERRC STU Champion 2010
    __________________
    May 2003
    Lagrangeville, NY
    694
    it is usually driver right just before the west bend.
    Chris Raffaelli
    NER 24FP
    Mar 2001
    Connecticut
    7,381
    Quote Originally Posted by lawtonglenn View Post
    You'll see the guy sitting about halfway down the straight between the Uphill and West Bend, driver's right. Usually an older guy in a worker white suit with a tripod.
    Point your tail pipe driver's left.
    ...is the distance/config different enough to make it of comparable difficulty meeting?
    It's comparable to the distance at NHMS, plus he's not up against a concrete wall that could reflect the pressure waves.
