Results 1 to 11 of 11
Thread: T II Hood
    Sep 2005
    13
    Default T II Hood
    Is it legal to use a T II alum hood in ITS on a 2nd gen RX7?
    8,607
    Not if it's different than anything that came on non-turbo versions.
    Dec 2006
    Dallas, TX
    564
    Quote Originally Posted by hawke3 View Post
    No.
    You can only swap parts from 86-91 NA models.
    Mark B. - Dallas, TX
    #76 RX-7 2nd Gen
    SCCA EP
    Former ITS, ITE, NASA PT
    Jan 2008
    115
    Default hoods
    hawke , you have some choices , a flat stock alum hood @ about 26lbs. a flat stock steel hood @ about 56lbs. or a aftermarket flat steel hood @ about 38lbs. hope this helps ralph
    Oct 2002
    Wandering the USA
    1,341
    Quote Originally Posted by racingralph View Post
    Umm... why would this be legal?
    Marty Doane
    ITS RX-7 #13 (sold)
    2016 Winnebago Journey (home)
    Dec 2008
    Orlando, FL
    1,391
    Obviously not an exact OE equivalent, so it would not be. but does it matter, really? if you can legally run a lighter, stock hood, then why would anyone's feathers get ruffled by the (admittedly illegal) aftermarket steel hood, assuming it is indistinguishable in contour and fit?
    Sep 2005
    13
    Thanks, I did luck out and found an na stock aluminum hood
    Feb 2005
    Woodstock, Ga
    57
    Aftermarket hood politically not correct to use but you can use it who cares,no advantage go for it. (The T II hood no go)
    Attila Lukacs -ITA/7 #39
    Woodstock, GA
    03-05 ARRC champ.
    03-08 Pro-it champ.
    RoadRunner Auto Repair & Racing
    770-720-2039
    RX7/3 parts & more
    https://www.roadrunnergarage.biz
    https://www.facebook.com/roadrunnergarage?fref=ts
    Jun 2009
    Wichita, KS
    4
    I hope this isn't out of line, but I thought I'd point out that I have an aluminum non-turbo hood for sale, along with a bunch of other FC parts in the Classifieds section.
    Jul 2008
    4
    Just curious, what if the car is an 89-90 GTUs - it is NA but came stock with alum hood.
    Quote Originally Posted by Eagle7 View Post
    as already stated technically it might not be, but if your going to start bitching about bodywork then everything better be oem... better buy it from a dealer to make sure otherwise the chinese stuff you can buy for a lot less won't be a 100% perfect match down to the weight. The reality is I think most cars that have been wrecked likely have illegal fenders, bumper, etc. unless they pulled them from a junkyard car or bought from a dealer. Even then you never know for sure unless it has a factory part number. lots of cars in boneyards with aftermarket body panels as they are common in the collision industry. I wouldn't put it past a dealer to sell aftermarket either for the bigger profit margin/quicker availability.
