Results 1 to 10 of 10
Thread: CV Joint Clearance
    Aug 2005
    Brunswick, Oh
    150
    Default CV Joint Clearance
    New outer cv's for A1's from GKN will not clear spindle. I guess GKN are only making the larger ones for A2's and up. I was able to machine them to fit. What are other options for us A1ers? Late model spindels and brakes? Machine spindles? Or just keep on machining the cv's?
    ITC #05
    '82 Jetta
    NEOhio
    Shutter-Up Inc.
    Olmsted Auto Care
    Light Doctor
    Apr 2001
    Belmont, CA USA
    1,098
    I had that problem a couple of years ago. The diameter of the outer CV on some are larger than others, and would touch the bottom of the hub carrier. I had to try a couple of times to get the correct ones.
    I guess it's time to just rebuild them, instead of replacing the entire 1/2 shaft assembly.
    I would take some dimensions, and specify the differences and only accept the smaller diameter ones.
    Tim Linerud
    San Francisco Region SCCA
    #95 GTL Wabbit
    Convert from GP to GTL
    racer_tim @ yahoo dot com
    Y'all aren't going to like the "book answer" on this: Lack of a parts stream hasn't ever been something we can consider, except as described by the "supersede" allowance in the ITCS.
    Technically, none of those options are within what's allowed.
    Aug 2006
    384
    I had this same problem, and was able to find some that fit. Some mount to the shaft with a recessed ring, while others use a regular circlip. Only problem is I don't remember which was which. I found two new one and used those and hopefully they last awhile, since its the inboard ones that always go. I have to take one of the axles out this week anyway and Ill get back to you.
    Nov 2005
    Nebraska City
    223
    Same problem here, hope these new ones from parts4vws fit better. They are sold as 90's for the A1.
    Should know this week.
    Dave Webb
    Bare Bones Racing
    '84 VW GTI
    #17 ITB
    Sep 2008
    FL.
    1,384
    90mm outer will fit. Some rebuilders dont watch what size the outer is. They look the same. You can also find some 80mm, setups. Might go faster , for a while. MM
    Aug 2005
    Brunswick, Oh
    150
    Quote Originally Posted by keycom View Post
    That's where I purchased mine. The guy I talked to said no more GKN's for us. Only Empi's. Which only lasted 2 weekends for me.
    ITC #05
    '82 Jetta
    NEOhio
    Shutter-Up Inc.
    Olmsted Auto Care
    Light Doctor
