Results 1 to 15 of 15
Thread: Brake Hydralics - HELP!!!
    Jan 2003
    Rockaway, NJ
    1,548
    Caplipers aren't seized - the pistons move no problem.
    I'm leaning towards a clogged up ABS pump - one Porsche expert suggested that enough moisture may have seeped in while the car was sitting that the ABS pump got corroded. I believe that's up behind the passenger fender - going to pull that off and see if I can get any fluid before the pump. That would also explain why the fronts barely bleed.
    I have the factory manual - not the greatest - I was suprised how little it had on the braking system.
    BenSpeed
    #33 ITR Porsche 968
    BigSpeed Racing
    2013 ITR Pro IT Champion
    2014 NE Division ITR Champion
    Royal Oak, MI, USA
    1,599
    Yikes... sucks/wierd that you'd have to have the ign on to bleed - all our Bosch systems (at least for sure 5.X-onward) are all flow-through - can bleed with ignition off.
    If you pull the rear lines off after the ABS unit and see about blowing air through there, you should be safe and also isolate any issues that might occur with the ABS unit; it should be safe against sticking, but hey, who knows...
    Vaughan Scott
    Detroit Region #280052
    '79 924 #77 ITB
    #65 Hidari Firefly P2
    www.vaughanscott.com
    Jan 2003
    Rockaway, NJ
    1,548
    Must have said something wrong - don't need the ignition on to bleed although I tried both off and on. Didn't make a difference.
    Thanks Vaughan - will let you know how this turns out - likely will post more info for help!
    BenSpeed
    #33 ITR Porsche 968
    BigSpeed Racing
    Oct 2003
    long valley, NJ
    335
    Ben-if it's the late German syndrome, you need to force the fluid thru with the hi pressure type bleeder, not pump it thru w/pedal. If it's this case, you will not be able to get a decent peadal no matter how long you pump the pedal! phil
    phil hunt
    Dec 2003
    358
    Ah, I forgot about ABS... Used to my old cars Yep, there's a special procedure for that, and IIRC, it does require a pressure bleeder (I don't have it handy, but have it somewhere on my Audi service DVD somewhere)
    Jan 2003
    Rockaway, NJ
    1,548
    OK - here's and update. I was able to isolate the blockage down to the abs pump. Fluid will not come through to the rear line. I checked EVERY line and the calipers with compressed air. Made sure to disconnect the ABS first.
    Sure learned more about brake hydraulics than I knew before.
    Looks like a new ABS pump will solve this problem.
    BenSpeed
    #33 ITR Porsche 968
    BigSpeed Racing
    Jan 2003
    Rockaway, NJ
    1,548
    ABS pump fixed the problem - car is running sweet.
    BenSpeed
    #33 ITR Porsche 968
    BigSpeed Racing
