OK - here's and update. I was able to isolate the blockage down to the abs pump. Fluid will not come through to the rear line. I checked EVERY line and the calipers with compressed air. Made sure to disconnect the ABS first.
Sure learned more about brake hydraulics than I knew before.
Looks like a new ABS pump will solve this problem.
