Yikes... sucks/wierd that you'd have to have the ign on to bleed - all our Bosch systems (at least for sure 5.X-onward) are all flow-through - can bleed with ignition off.
If you pull the rear lines off after the ABS unit and see about blowing air through there, you should be safe and also isolate any issues that might occur with the ABS unit; it should be safe against sticking, but hey, who knows...
