Results 1 to 6 of 6
Thread: NASA to SCCA
    Jul 2008
    2
    Default NASA to SCCA
    I recently purchase a NASA run RX7. I was wondering if anyone has gone back and forth between NASA & SCCA. I would like to be able to run with both groups.
    Car had an annual tech for 2008 w/Nasa, no SCCA log book.
    What were the biggest changes needed to run with both? i.e. any big structural changes to the cage. I've read through the CCR's for SCCA, but I'm still a bit confused. Car would probably run ITA (currently set for PTF)
    Any help would be appreciated.
    8,607
    Your best bet is probably to prepare to an SCCA class like Improved Touring, then run whatever Performance Touring (PT) class you end up in. PT allows way more flexibility so is easier to drop into but be warned that some IT improvements earn disproportionately more PT "points" than it seems like they should. The nature of the two rule sets is VERY different, with IT being way more prescriptive.
    Feb 2003
    Scottsdale AZ
    322
    Quote Originally Posted by dryan View Post
    Is it a Pro7 or Spec7 car? Those are regional classes (Spec7 is SoPac; Pro7 is both I believe).
    Spec RX7 #11
    Scottsdale AZ
    Apr 2001
    Belmont, CA USA
    1,098
    Here are the San Francisco Region supps for it's SRX7 class
    http://www.sfrscca.org/images/2009/rx7rules.pdf
    It is also a legal ITA car, but with the limitation of the stock 13x5.5" wheels and exhaust manifold, it would never be competitive in in ITA.
    Tim Linerud
    San Francisco Region SCCA
    #95 GTL Wabbit
    Convert from GP to GTL
    http://www.timlinerud.com/racing/index.html
    racer_tim @ yahoo dot com
    Wauwatosa, WI, USA
    2,658
    It is also a legal ITA car, but with the SRX7 limitation of the stock 13x5.5" wheels and exhaust manifold, it would never be competitive in in ITA.
    Have Fun ; )
    David Dewhurst
    CenDiv Milwaukee Region
    Spec Miata #14
    Jan 2004
    Camas, WA
    531
    Who's car did you buy?
    Marcus (nasa norcal regular, with some SCCA time
    Marcus
    miller-motorsports.com - Its always an Adventure (and woefully outdated)
    1.6 ITE/SPU/ST2 Turbo Miata (in pieces... err progress)
