Results 1 to 7 of 7
Thread: Jax chassis dyno
    Jan 2005
    Alachua, Florida
    261
    Default Jax chassis dyno
    Does anyone know of a reputable shop with a chassis dyno in or near Jacksonville Florida? TIA
    Steve Elicati
    ITA 1994 Mazda Miata
    Central Florida Region
    Jan 2005
    Alachua, Florida
    261
    Okay how about within 100 miles or so. help!
    Steve Elicati
    Apr 2008
    774
    are you wanting to do the tuning or do you want some to do it for you? We use one here in longwood area. I think it is 100 bucks for the first hour then 60 for every one after.
    Track Speed Motorsports
    [email protected]
    Jan 2005
    Alachua, Florida
    261
    I'm not sure what I can tune other than the timing and a/f ratio. I'm installing a new engine and want to make sure all is good before it hits the track. The a/f is my main concern.
    Steve Elicati
    Nov 2005
    Jacksonville, FL
    734
    Hi Steve,
    I'm in Jax also and haven't found anyone around here to use. I believe some of the local IT guys have used Stage 6 Motorsports for dyno tuning but I haven't personally worked with them.... http://www.stage6motorsports.com/
    Christian
    Apr 2008
    774
    I was not aware of what kind of computer you had. You could be tuning a motec if you wanted to. However in yoru case any dyno will do. here is a quick list of dynos in the florida region. You can look through it and find one close to you.
    http://www.mustangdyne.com/LocatorPages/DynLoc_FL.htm
    [email protected]
    Jan 2005
    Alachua, Florida
    261
    Thanks for the help guys I'm headed to stage 6 on friday to check the place out.
    Steve Elicati
