Results 1 to 5 of 5
Thread: Harness question bolt in or snap in?
    Oct 2008
    26
    Default Harness question bolt in or snap in?
    What is better? What is easier? Why?
    Dec 2001
    St. Louis, MO
    1,215
    I'm sure this will turn into an informative thread!!!
    I think that if they're done correctly, neither is "easier" The snap in's should be safety wired once installed, so that pretty much negates any ease of removal since you usually have to remove the seat to get to the sub straps to remove the wire (unless you're a contortionist with very small hands).
    Most bolt ins I see are angled wierd and not able to articulate (kind of early so excuse me if that's the wrong word for what I'm trying to convey).
    I usually remove the hardware for the shoulder straps and go for the wrap around style. 3 less things to go wrong (no bolt, clip or bracket).
    Scott Rhea
    Izzy's Custom Cages
    It's not what you build... It's how you build it
    Performance Driven LLC
    Neon Racing Springs
    Buffalo, New York
    2,942
    Go with the less expensive--the bolt in.
    I too Wrap the shoulder harnesses. I also use the OEM bolt holes for the car's original belts--if available and in range of where they should be for the race belts. Otherwise I weld a plate and captive nut.
    8,607
    I really like the fact that snap-in harnesses (tend to) self-align, so they are in tension. (I think that's what Scott is talking about.) I've seen lots of bolt-in harnesses (mostly in formula cars) where the direction of pull puts the end fitting in a weird bending situation.
    Dec 2001
    St. Louis, MO
    1,215
    Thanks Kirk... yes that's what I was trying to convey.
    Factory mount locations aren't always the ideal angle for the lap belt mounts. Consult your instructions for the proper angles.
    Scott Rhea
    Izzy's Custom Cages
    Neon Racing Springs
