Results 1 to 10 of 10
Thread: Air pump 1986 Nonturbo rx-7
    Feb 2009
    St. Louis
    31
    Default Air pump 1986 Nonturbo rx-7
    Does anybody know if you can remove the air pump without damaging the engine? I heard that the air pump helps oil the engine. I have looked all over the place and can't seem to get a straight anwer.
    CIII
    May 2008
    CT/NY/NJ
    1,157
    I have a first gen GS so I don't know the details for your model but I would reccomend you check out rx7club.com. The Tech part of the forum is quite the wealth of info and MOST of the people are not assholes. Search it there, I'm sure you will find it!
    Chris Rallo "the kid"
    Apr 2002
    San Francisco
    77
    I think you are mistaking the metering oil pump. The air pump is an emission device used to inject air into the exhaust. If you do remove the air pump and belt, you may have to watch for belt slippage on the water pump pulley though.
    Dec 2006
    Dallas, TX
    564
    Air Pump - yes you can remove, no problem. At high RPM may have belt slippage, fix that with a dual alternator pulley. While you are at it, replace the main pulley to underdrive the water pump and reduce cavitation.
    Oil Metering Pump (OMP) - I do not believe that is IT legal to remove, it's been debated on here before I think if you search. Removing will not hurt the engine, but you MUST pre-mix your fuel at about 1oz/1gal.
    Mark B. - Dallas, TX
    #76 RX-7 2nd Gen
    SCCA EP
    Former ITS, ITE, NASA PT
    Jun 2006
    28
    What about the air control valve? Its a device that mounts between the 5-6 port actuators that air from the air pump seems to pump into. Can you get rid of that too? I assumed it was only for emissions.
    I'm just starting to build my '87 as well and this is my first rotary. Any help is appreciated. Thats good to know about the possible belt slippage.
    Dec 2006
    Dallas, TX
    564
    Quote Originally Posted by jcocke View Post
    Make your own blockoff plate or buy one, there are a few companies that sell different block off plates for stuff.
    http://www.pineappleracing.com/index...ROD&ProdID=100
    Check out www.rx7club.com - ton of information, this is where you will learn the most about the 2nd Gen. Before you even get going on this project, you can save a lot of time and money by doing lots of research. You probably haven't figured out yet that you can put an '89-91 intake on your '86 and pickup 15rwhp. The 5-6 port actuators you will want to remove (and the IT rules permit this).
    #76 RX-7 2nd Gen
    SCCA EP
    Dec 2003
    358
    Quote Originally Posted by mbuskuhl View Post
    Just for my own understanding, where does it say two belts are legal?
    You've got this:
    2. Rotary engines (only)
    c. Crankshaft pulley is unrestricted.
    And this:
    n. Alternate water pump, alternator, power steering, and crank-
    shaft pulleys of any diameter or material may be used. Type of
    accessory drive (e.g., V-belt, toothed belt, etc.) shall remain as stock.
    but I thought if it doesn't specifically allow it you can't? Not like I'd protest it or anything, but just curious.
    Apr 2002
    San Francisco
    77
    On all the rx-7's that I know of that removed the air pump, the belt only slips if your still running the fan clutch. With an electric fan, you do not need the dual alternator pulley.
