Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Cage Fixing Time
    Jul 2004
    Raleigh NC
    3,682
    Question Cage Fixing Time
    I've got my car apart for a new motor and I'm trying to fix some issues that I have found. First up the cage.
    On the driver's side, do you think I'll lose any cage integrity by deleting that lower bar on the driver's side long with the tooth pick bars that attach it to the second bar? I'm searching for weight anywhere I can find it. Yes, I know I have to fix that illegal set mount too, it can't be attached to the cage (cage was done in 1993, Atlanta area).
    On the passenger side what is the lightest and safe design I can use that will protrude out into the door so I can gut the door? What I have now is shown and that seat isn't installed in my car, just sitting there for storage purposes.
    Thanks,
    Ron
    Aug 2007
    Northern, CA
    217
    Ron I would not change anything On the drivers side it looks very good and safe the way it is. not worth losing the weight IMO.
    Passenger side I would basically do the same design you have but make the top one lean every sol slightly into the door.
    Just my 2 cents.
    Mike Uhlinger
    Sep 2005
    La Habra, CA
    144
    Yes.
    "X" bar that points/curves into the door area.
    St. Louis, MO
    1,215
    I wouldn't touch the drivers side unless you're willing to cut it all out and start over.
    Assuming that the tubes are the min. size (1.75x.095 instead of .120), IF you feel like you have to do something to the cage, I'd actually take the top bar off and use the next size smaller tube for the top rail and the "toothpicks". In other words, if the bottom bars both meet the min. req., use 1.5x.095 on the top bar/stringers.
    Pyramid X on the passenger side is the lightest, but I'd do a pyramid X with a sill bar for the strength (see the Miata impacts from late last year). Again, sill bar and main diagonal on the X would be the required, split bars would be smaller diameter or thinner walled. Don't forget your gussets.
    After all is said and done, you'll probably drop 6-8 lbs total.
    1.5x.095 =1.426 lbs per foot
    1.75x.095 =1.73ish lbs per foot
    1.5x.120 = ~ 1.87 lbs per foot
    1.5x.065 =.99 lbs per foot
    Scott Rhea
    Izzy's Custom Cages
    Performance Driven LLC
    Neon Racing Springs
    Nov 2005
    Jacksonville, FL
    734
    Entirely my $0.02 but if you're looking to lose weight on the car, I'd cut out and redo the bars on both sides. Have you thought about doing a two bar setup like I had done on my car? Gives you most of the weight savings of an "X" design but way more strength along with the legal allowance to gut the doors.
    Christian
    Jul 2004
    Raleigh NC
    3,682
    Hey Christian,
    Does Cameron do bars? I think I'm going to do what you and Scott suggest. Cut that stuff out and put new stuff in. 1) for weight savings, 2) so I can legally gut that passenger door. Door guts is heavy!
    R
    Nov 2005
    Jacksonville, FL
    734
    Nope... Cameron isn't a "cage guy". I had my cage done by Chris Schimmel at Competition Cages (up your direction). Here's his site: http://www.competitioncages.com/
    Christian
    Jul 2004
    Raleigh NC
    3,682
    Yep, Chris has done a few cages for me/us over the years. I just was wondering if Conover might be able to do a fix type job. I'm sure Chris can knock this out in no time. I'll get it up to him once I have a trailer to get it there!
    Aug 2001
    rutherfordton,NC,28139
    254
    Default weight
    HI Ron,
    On my car, We added a small half loop welded to the pass side cage....12-14 inches long to just reach into door cavity..... seems we lost close to 20 pounds removing the innards of that door..... Course I've managed to put it right back in the drivers seat.....
    FWIW... I've never really turned down pressure to the rear drums...Have you? I rode around with a regulayer for years, til I relized ....never really use it. Never had problem locking rear drums....unless combined with sloppy downshift.
    Wheels are on my list to reduce weight..... Once my 401-K recovers..... Or if my stimulus package application is accepted this time.....
    Several pounds to be gained optimizing rules allowance for smaller tubing on none required cage parts........ I do have a shell in the backyard that has the smaller/lighter cage....but havn't needed to finish since my current car showed up out of the blue...
    Hope to see you guys on the track this year.......
    david
    30 year old ITS car
    Jan 2009
    Athens GA
    37
    What is illegal about the seat mount?
    Jun 2005
    Kansas
    532
    It appears to be welded to the cage, and fastened to the floor. Therefore, it technically constitutes a 7th roll cage attachment point.
    Gary Learned
    MiDiv
    Volvo 142E
    http://www.youtube.com/user/denrael
    Jan 2009
    Athens GA
    37
    Quote Originally Posted by Gary L View Post
    That's illegal? Wow. So if you want to tie the bottom of the seat to the cage, it can't be attached to the floor also? That is going to make for a tricky mount.
    Sep 2001
    hampden,ma.usa
    3,083
    If you mount the seat to the cage instead of the floor the rear is easy and the door side is easy but if you attach it to the tunnel it becomes an extra attachment point. I am also a tech inspector and have issued logbooks to cars that have that kind of setup if I felt the seat was safe and I have never heard of a protest but technically I do not think it is legal.
    dick patullo
    ner scca IT7 Rx7
    Jan 2009
    Athens GA
    37
    That might be something to think about rules wise. It is rare for sure, but occasionally race cars come to rest on their sides, and an unreinforced floor pan offers no protection at all. I don't really see how some tubing under the seat, between the rails and the tunnel would ever be a bad idea.
    Sep 2005
    Earth
    743
    To quote Kirk et al, "slippery slope"
    Ed Funk
    Sep 2001
    hampden,ma.usa
    3,083
    I agree Ed but I would love to come up with a solution to be able to mount a seat more securely. If anyone wants to try to write up a rule that would help find a solution I am sure there are plenty of us that would be willing to critique it.
    dick patullo
    ner scca IT7 Rx7
    St. Louis, MO
    1,215
    You can still mount the seat to a frame that attaches to the cage... just takes a little more tubing and some non attached plates to support the seat.
    The only corner not attached to the cage is the front right and it has a support pad under it, as does the front left and right rear.
    There has been a few instances of a roundy round hornet flipping on its side, drivers side down, and being T boned. Never ends well
    Scott Rhea
    Izzy's Custom Cages
    Neon Racing Springs
  18. #18
    Jan 2006
    219
    My seat mount is similar to pic above. Mounted/welded to cage, and the one contact point not welded to the cage is "resting" on the floor.
    -Tom
    ITA Integra | 05 Mazda3 | 03 Mini
    http://www.tomhoppe.com
  19. #19
    Nov 2004
    Lilburn, GA
    597
    That's how I'm planning on doing the seat mount in the new body. Have it part of the cage. You can have it touch the floor all you want, you just can't weld it to the floor. Same as the downtubes that will be touching the floor with plates on the bottom to serve as jacking points. :cool:
    ITA 240SX #17
    Atlanta Region
  20. #20
    Black Rock, Ct
    9,594
    Quote Originally Posted by DavidM View Post
    Position those plates over drain holes if you can, and build a "curved top" insert for your jack pad. Project a bolt through the insert sicking up, and drill a hole in your plate, and your jack now registers with the car, eliminating the car slipping off the jack when the jack is resistant to rolling on less than perfectly clean flat floors.
