Results 1 to 3 of 3
Thread: Torsen diff question
    Feb 2005
    Basking Ridge, NJ, USA
    267
    Default Torsen diff question
    I run a 4.88 torsen diff in my second gen, and am considering building a spare diff of mine into a torsen 5.12 -Hoping you guys could answer some questions about the torsen. (bear with me im not very familiar with diffs)
    -Where do the torsen components come from? 94-98 miata?
    -does this all drop into the stock 2nd gen housing?
    -wouldent it be illegal to run an entire 94 miata torsen diff?
    -how much does whatever im looking for cost!? (i already have a spare 2nd gen diff and im aware of the RandP cost)
    Thanks a bunch!
    Aug 2004
    Durham, NC
    45
    Here are the short answers:
    1) In general the torsen units come out of the 94+ 1.8L Miatas. The 94-98 model years should work. I do not know about more recent models.
    2) It is a drop in replacement for the 2nd gen NA open diff. There only issue seems to be if you have an S5 (89-91) viscous type diff, then the stub shaft lengths will be wrong and you will need a set from an open diff.
    3) Per the GCR you have to use the case from the RX-7, but the actual unit is open.
    4) Miata torsens seem to be going for around $400+ right now.
    Go over to www.rx7club.com and search the forums for "torsen swap". Crispy also has a decent writeup of the operation here:
    http://www.negative-camber.org/crisp...c/fcpart17.htm
    Hope this helps,
    -bill
    Feb 2005
    267
    yes it does, thank you bill!
