Results 1 to 9 of 9
Thread: Civic Control Arms
    May 2006
    Bay City , Mi .
    86
    Default Different UCA's .
    I have bought them for both and the aftermarket ones I got for a 90 Civic Si had a seperate ball joint . But the ones I bought for an 88 Civic standard were attached .
    They are diminsionally the same part If I'm not mistaken ?
    Does anyone else have a better idea ?
    Todd Robbins. [email protected]
    Nov 2005
    Jacksonville, FL
    734
    Correct dimensionally identical...
    When I had my 89, I went to the junkyard and looked until I found a set with separate ball joint and then replaced the ball joint. I didn't think to look at what year the car was
    Sep 2005
    49
    I have seen them both ways for the same year. I have a set of stock ones with INGALS adjustable ball joints if you are interested. New!
    Jun 2002
    28
    How much negative camber could I get with these control arms / ball joints? What do you need to get for them? Thanks.
    Nov 2005
    Jacksonville, FL
    734
    Adjustable ball joints aren't IT legal... offset bushings only.
    May 2006
    Bay City , Mi .
    86
    Default front control arms .
    The amount of - camber you get from a frony control arm without offset bushings is dependent on how much lowering you induce .
    With the IT legal ride height in our 91 ITC civic we were at about -2deg +or- .
    It's been a while since we sold the car though .
    Dec 2008
    1,391
    Quote Originally Posted by tcc1577 View Post
    like Xian said, the ingals adjustable balljoints are not allowed in IT, but for academia's sake, you can get ±3° or so with them from stock at whatever lowering position. the real trick is that they allow a reasonably easy caster adjust, too.
    IT legal offset bushing are hard to get a wrench to, but work well and give you ~±2° caster AND camber. IT questionable slotted UCA mount replacements give you a bit more adjustemnt and are much easier to adjust. Ingals sells all 3 types, IIRC.
