Results 1 to 20 of 22
Thread: whistler
    Apr 2001
    NH, US
    3,821
    Default whistler
    Anyone have one or know someone who does???
    Raymond
    RST Performance Racing
    www.rstperformance.com
    Sep 2005
    1,489
    SCCA has one, it gets used just a "little" at the runoffs.
    Travis Nordwald
    1996 ITA Miata
    KC Region
    Jan 2003
    Los Lunas, NM, USA
    682
    SCCA has two and, yes, they get used a bit at the runoffs.
    Club Racing bought the second one used from Pro, when Trans-Am went down...
    Ty Till
    #16 ITS
    Rocky Mountain Division
    2007 RMDiv ITS champion
    Bunker Hill,WV.
    614
    Raymond
    We have one here at our shop. What would you like to know.
    Dave Parker
    "Ignore All Confrontations With Common Sense."
    Apr 2001
    NH, US
    3,821
    For those that don't know what it is....
    Static engine compression ratio meter
    The WHISTLER is an electronic device that instantly determines the compression ratio of virtually any engine.
    Using the WHISTLER is easy, just remove a spark plug and screw the WHISTLER adapter in its place. Enter the number of cylinders, CID, and temperature of the engine into the WHISTLER. Then, bring the engine to TDC and the unit will display the compression ratio to the nearest tenth of a point.
    http://www.katechengines.com/corpora...s/whistler.php
    Dave-
    I would like to get one to an event next season... If it is sooo easy to use I don't know why we wouldn't use one next season at a random event in tech for a spot check.
    Raymond "The Steward in me" Blethen
    Sep 2005
    La Habra, CA
    144
    Well, for one thing they cost over $2,000, which is a chunk of change for Tech.
