Results 1 to 7 of 7
Thread: FC transmission advice needed
    Jan 2003
    Huntsville, AL
    316
    Default FC transmission advice needed
    I just picked up an '89 RX-7 GXL, and need some help. I can't get the thing to shift into neutral. I can get 5th or R, but I need it to go into neutral (makes it easier to push around). Is this a shifter malfunction or an internal malfunction?
    I tried removing the shifter and manually pushing the socket around, still no luck finding neutral.
    Any ideas appreciated.
    Thanks
    Eddie
    Eddie
    ex RX3 and GTI driver
    "Don't RallyCross what you can't afford to Road Race" - swiped from YH and twisted for me
    "I have heard that any landing you can walk away from is a 'good' landing. I bet this applies to flying airplanes as well." - E.J.
    Jan 2003
    Rockaway, NJ
    1,548
    I would drain the trans and look for little pieces....
    I just bought an ITS RX7 and plan on having three transmissions. One in the shop, one one the trailer and one in the car. Having blown up at least 5 in my ITS career....
    BenSpeed
    #33 ITR Porsche 968
    BigSpeed Racing
    2013 ITR Pro IT Champion
    2014 NE Division ITR Champion
    Asheville, NC US
    1,626
    Internal problem with the shift rods. Sounds like a stuck detent. Drop the 4 bolts from the rear drive shaft flange and drain the trans. Street or race car?
    Steve Eckerich
    ITS 18 Speedsource RX7
    ITR RX8 (under construction)
    Jan 2003
    Huntsville, AL
    316
    Quote Originally Posted by seckerich View Post
    Street or race car?
    I did sell the ITB car
    Seriously, don't know what I'm going to do with it yet. A friend of mine drove it into a sign post and ripped the front right corner off of it. I'm now looking for the following for 89 and later FC:
    Passenger lower control arm
    Rack and pinion
    Passenger fender
    Passenger fender light fixtures
    front bumper cover
    Passenger strut assembly (with fact. adj susp), including rubber mount
    As for the trans, I think it was damaged when the punks in the impound yard decided to steal the stereo system. They made a mess of the dash, and I suspect they leaned on the shifter so hard they broke something. The crash wasn't hard enough to hurt the trans. The other possibility is that the wrecker dragging the car onto the rollback in gear damaged the tranny. I dunno - that's why I'm seeking advice.
    Eddie
    Central Florida
    1,225
    Might have the strut and control arm if you're interested. Possibly a power rack assy also.
    cwire at therecoveryroom dot com
    Chris Wire
    Team Wire Racing ITS #35
    www.themotorsportshour.com
    "Road Racing on the Radio"
    WPRK 91.5 FM
    wprkdj.org
    Feb 2005
    Woodstock, Ga
    57
    Plenty parts here call me or I going to be at Road Atlanta this weekend.
    Attila Lukacs -ITA/7 #39
    Woodstock, GA
    03-05 ARRC champ.
    03-08 Pro-it champ.
    RoadRunner Auto Repair & Racing
    770-720-2039
    RX7/3 parts & more
    https://www.roadrunnergarage.biz
    https://www.facebook.com/roadrunnergarage?fref=ts
