Results 1 to 14 of 14
Thread: VW solid rotor front brake pads
    Bunker Hill,WV.
    614
    Default VW solid rotor front brake pads
    Hi
    For those of you who are racing an A1 Volkswagen with solid front rotors.
    As you may or may not know Hawk Performance Brakes has discontinued the HB189E.760 (Blue Compound) brake pad that is the correct thickness for the solid rotor cars.
    My employer is a Hawk Brake dealer. I have asked Hawk Brake if they will make a production run of these brake pads, they will make them,but I must commit to buying twenty-five sets.
    I will make the price as low as possible.
    If you are interested in some of these pads please feel free to contact me at dave at kingratmotorsports (dot) com or call me at 540.955.9696.
    Thanks
    Dave Parker
    "Ignore All Confrontations With Common Sense."
    Jun 2007
    Reston, VA
    236
    :mad: great...
    Tristan Herbert
    2011 World Challenge TC Rookie of the Year
    2011 ARRC ITB Champion
    2011 IT Fest ITB Champion
    2009 MARRS - ITB Champion
    BRIMTEK/Germanautoparts.com
    Bunker Hill,WV.
    614
    Tristan
    This pad being discontinued does not effect you. Your car is a vented rotor car that I have pads in stock for.
    Dave
    Aug 2005
    Brunswick, Oh
    150
    Can't we use the vented rotor pads on non-vented? They would just be thinner I'm interested in a set.
    ITC #05
    '82 Jetta
    NEOhio
    Shutter-Up Inc.
    Olmsted Auto Care
    Light Doctor
    Jan 2008
    8
    Quote Originally Posted by jay05 View Post
    I'm wondering about this myself. I know hawk still offers .595 and .550 thickness. Will .595 thickness work well enough? Does anybody else offer the extra thick pads?
    I currently need front pads for a solid rotor 1980 Rabbit ITC car.
    Wheaton, IL
    1,893
    TIG weld an old backing plate to the vented rotor pad.
    Chris Schaafsma
    Golf 2 HProd
    Apr 2001
    Belmont, CA USA
    1,098
    The problem with running the thinner pad in the solid rotor setup, is that you are outside of the normal "travel" of the caliper, and depending upon the wear pattens of the caliper, you might loose a seal, or cause the seal to burst, and then you have no pedal at all.
    I still have some sets of "think" pads, but don't know what compound they are. These were from my ITB VW Scirocco that was a 1.7 and had to use the solid rotors.
    Tim Linerud
    San Francisco Region SCCA
    #95 GTL Wabbit
    Convert from GP to GTL
    racer_tim @ yahoo dot com
    Wheaton, IL
    1,893
    Right. So adding thickness to the backing plate compensates for that issue.
    Chris Schaafsma
    Golf 2 HProd
    Nov 2005
    Rochester, NY
    553
    http://www.tispeed.com could make ones that as the exact shape of the backing plate would not need welding but is there enough interest?
    Jan 2008
    8
    I'm thinking it might be better just to ditch the solid rotors and get vented ones.
    It's looking like this car is going to be more of an autocross/track day car than an ITC car anyway.
    Bunker Hill,WV.
    614
    For a track day car the above ideas are probably fine. Unfortunately for those of us racing these cars in classes like IT or Production means that you must have the correct stuff (unless you want to be labeled a "cheater").
    Sadly, Hawk Brake showed no interest in producing the order even though I had forty sets sold. Then during October of 2008 my employer (at the time) ceased operations leaving me unemployed. I was rather bummed about the whole deal. I am still trying to figure out what to do about proper brake pads for my racecar.
    Sorry.
    dave parker
    Sep 2008
    FL.
    1,384
    Welding to the backingplate also allows the modification of the backing plate. IE; venting through airholes, heat sinks, etc. Great idea Chris.
    Kinda like slotting the plate to add some airflow past the piston. Been done for some time now.
    MM
    Mar 2004
    Toronto
    135
    I just ordered some 19.7mm/.775" front pads from Carbotech. They are still making them in different compounds. We'll see how that works.
    They were not cheap but nice guys to deal with.
    http://www.ctbrakes.com/
    Joe Camilleri
    HP Scirocco
    Check out the VW Club Racers Facebook page: http://www.facebook.com/group.php?gid=309326556818
    Oct 2003
    long valley, NJ
    335
    The only difference between vented/non-vented pads is lining thickness; there is no problem with caliper failure. They just wear out sooner.
    phil hunt
