Results 1 to 6 of 6
Thread: Fuel Cell Metal Can
    Jul 2006
    Prattville, Alabama
    129
    Default Fuel Cell Metal Can
    Not to re-hash the FIA/SFI/Rotary molded debate...
    If I use a fuel cell enclosed in a metal container in the hatch area of my car, does the metal can constitute a "bulkhead" or must the entire hatch area be isolated or closed-off with sheet metal?
    Thanks,
    Todd
    Sep 2001
    hampden,ma.usa
    3,083
    You still need a bulkhead to separate the fill cap and fitting connections form the cabin.
    dick patullo
    ner scca IT7 Rx7
    Jul 2006
    Prattville, Alabama
    129
    Quote Originally Posted by dickita15 View Post
    Thanks Dick,
    So the can itself serves as a bulkhead?
    So I just need to enclose or cover the opening?
    Thanks again,
    Todd
    Sep 2001
    hampden,ma.usa
    3,083
    I would not say that. I think the tech inspectors will consider the metal can to be part of the cell so the bulkhead should separate that cell from the cabin.
    Sorry if I was not clear.
    dick patullo
    ner scca IT7 Rx7
    Wauwatosa, WI, USA
    2,658
    Todd, to support what Dick is saying please read rule GCR 9.3.26.1. & GCR 9.3.26.1.a.
    If you would continue to use the OEM fuel tank please see rule ITCS 9.1.3.9.E.
    Have Fun ; )
    David Dewhurst
    CenDiv Milwaukee Region
    Spec Miata #14
    Jul 2006
    Prattville, Alabama
    129
    Thanks everyone for the help.
    Considering the T&E involved with a fuel cell , I'm going to repair (seal) my OEM tank. A fuel cell underneath will not be higher than 6" off the ground.
    It will require a lot off sheet metal work to move the cell "up" or inside the vehicle.
    A weekend with a sealant kit will be a lot easier.
    Thanks again,
    Todd
