Results 1 to 12 of 12
Thread: #1&4 cylinder misfire
    Mar 2006
    27
    Default #1&4 cylinder misfire
    I am having a misfire in cylinder 1&4. i have changed the coil and plug wires still nothing , any ideas???????????????????????
    Jul 2008
    18
    Quote Originally Posted by DaveBrooks View Post
    maybe like a model name and a year, that would help a bit
    Mar 2006
    27
    Sorry for that my brain must be misfireing too. 95 plymouth neon sohc
    Feb 2004
    st. louis mo.
    433
    Need more info ???
    Mar 2006
    27
    it misfires at idle. I pulled plug wires to see what cylinders and when i pull 1&4 nothinh happens. it only stumbles when I pull 2&3
    Jul 2008
    18
    So, basicaly 1/2 the coil does not work. And you said you changed the coil.
    1. check that the new coil is aclually good. Get a voltmitter/amiter and probe the coil. it should be like 1&4/(+)/2&3 or combination of the 3. in short there has to be same resistence between a pair of connectors on the coil. Check the coil resistence too inside.
    2. if 1 checks out, you will have to trace the wires all way back to the ECU and cheking for continuety.
    3. if 2 checks out, check the connectors for dirt, oxydaxation, etc...
    4. if 3 check out then its the ECU
    good luck.
    PS, did you get the exact same P/N coil as was originally?
