I got the same coil in fact I took it off my running street car. i checked continuity between the engine harness and the coil and it all checked out. then i plugged the engine harness into the main harness and checked for continuity from the coil to the main plug to the pcm. There i found a couple of faults. so it looks like I will have replce the harness from the pcm to the firewall.
