Results 1 to 15 of 15
Thread: Cautionary Tale - Aeroquip Pushlock hose
    Jun 2004
    366
    Default Cautionary Tale - Aeroquip Pushlock hose
    I had a -10 Aeroquip Pushlock hose fail last weekend at the fitting. In fact it pulled off of the barb. Both the hose and the fitting were from Aeroquip. I have used pushlock hoses for years for fuel and oil with no issues. The hose connection that failed was relatively new (3 years) and gave no indications of an impending failure when it was inspected this winter. Also saw no oil leakage in a pre-race inspection. This type of hose uses the same AQP liner that is in standard Aeroquip hose. It is rated at 250PSI at 300F.
    I will be running braided stainless steel from now on. If you are using pushlock you may want to add a hose clamp to each fitting - Aeroquip does not recommend this by the way.
    Scott Peterson
    KC Region
    83 RX7
    STU #17
    8,607
    Pulled off or popped off? That is, what force motivated it to come apart?
    Jun 2004
    366
    Good question but I am leaning towards popped off. It was the pressure line out of the engine to the first cooler. The hose was supported via adell clamps to another line. It wasn't stretched or in any tension.
    Scott Peterson
    KC Region
    83 RX7
    STU #17
    Dec 2001
    raleigh, nc, usa
    5,252
    I don't use those things -- they always scared me.
    Question -- did it happen on start during high oil pressure/low temps, or after running for a while?
    NC Region
    1980 ITS Triumph TR8
    Jun 2004
    366
    Near the end of lap 1. The car was up to temp and pressure. I had run a full qualifying session earlier in the day.
    The car took off to the right in turn 12. Thought it was a flat or that I had hit oil from someone else. Kept driving and trying to stay out of the way. Should have stopped
    Scott Peterson
    KC Region
    83 RX7
    STU #17
    May 2005
    Staying off the walls
    1,049
    +1. I have seen the standard hose ends hold on to the results of a crashes that should have been torn away.
    Tom Sprecher
    Central Florida
    1,225
    I've never had a problem, but just about all the hoses I've done I've backed up with a hose clamp.
    I think Aeroquip's non-recommendation about the hose clamps is half marketing and half tech-related. It doesn't do them much good to come out with a fitting that has to be helped out with a clamp. Logic suggests however, that including a clamp is safe, cheap insurance against the very thing that happened here.
    FYI, the rotaries do run much higher oil pressures than a pistoni-type engine, but the range is 85-120 psi, which should still be well within the normal operating window of these products.
    Chris Wire
    Team Wire Racing ITS #35
    www.themotorsportshour.com
    "Road Racing on the Radio"
    WPRK 91.5 FM
    wprkdj.org
    "Tolerance is the last virtue of a degenerating society" - Unknown
    Mar 2002
    Black Rock, Ct
    9,594
    I was going to mention the possibility of a partial blockage or stuck thermostat, but, off the top of my head, that shouldn't be a problem with the pressure regulator operational....
    IT-7 #57 RX-7 race car
    BMW 2003 M3 cab, sun car.
    GMC Sierra Tow Vehicle
    lateapex911(at)gmail(dot)com
    Mar 2006
    54
    I have also had this happen. You are at the uppers limits of the spec on the hose for temp. I use a hose clamp I don't care what they say it my motor. The oil coming out of the motor is about 300F
    Jun 2001
    Milwaukee, WI
    1,193
    Me too. Hose clamps now back it all up.
    "Most people have the will to win, few have the will to prepare to win.” - Bobby Knight
    Bill
    Planet 6 Racing
    Jun 2004
    366
    Quote Originally Posted by RX3 View Post
    Good point about temps - My oil temp gauge registers oil after it has traveled through two OE coolers. So it makes sense that it is hotter in the hose that failed than anywhere else.
    FWIW - we remove the theromstats and insert a machined dowel to block off the bypass channel in the coolers. That way they are always flowing oil no matter what.
    I ran solvent through the cooler last night - no blockage.
    I'm going to braided lines....this is a PITA
    Scott Peterson
    KC Region
    83 RX7
    STU #17
    Central Florida
    1,225
    Quote Originally Posted by mustanghammer View Post
    My guess is that what you didn't see during your cursory inspection is the hose aging from the inside out. Routine heat cycling at those temps, possibly helped by low winter temperatures, may have made the hose weaker on the inside with no indication on the outside. No way to catch it until it failed. Unfortunately, without a clamp as a fail-safe, the only likely outcome is the one you got.
    Chris Wire
    WPRK 91.5 FM
    wprkdj.org
    Jul 2004
    Raleigh NC
    3,682
    I don't think I'd mess with those things. I've heard about a couple of failures with them on www.gt40s.com. Making the braided hoses is a PITA and they are heavy, but at least you know what you are dealing with. Maybe these are best left on show and not go cars.
    Buffalo, New York
    2,942
    It's just a rubber hose on a barbed end.
    You have a race car; use real race hose (braid with fitting). If you are concerned about weight, get some surplus Startlite on eBay and use it with AQP fittings.
    Cheers.
  15. #15
    Jul 2006
    Kansas City
    21
    I've had one failure and since then I've used clamps with no issues. I'd prefer to use braided lines but had to resort to the pushlock as space was tight and wouldn't allow for braided lines and fittings.
    I don't have much faith in the pushlock since they are engineered to work the same as Chinese finger cuffs.
    Greg Heuer
    ITC Fiesta #92 (in progress)
    '65 Beach 5B FV #67
    '65 Sardini FV (not yet in progress)
    '03 Crown Vic aka "Tackleberry"
    "Racing more cubic inches requires more cubic dollars"
